SOURCE: DVD Stuck in TV/DVD Combo
This may not sound technical, but I stuck the end of a paper clip into the opening until I could feel the dvd.....jiggled it a bit, and out it popped while pushing the eject button!!!
SOURCE: remot not working for Sens TV/DVD 19''
Hi sifrid,
Program the RCA remote with the instructions below, this will tell us if the problem is with the remote or the tv.
Let me know if this helps and please rate this solution.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
SOURCE: PORTABLE DVD PLAYER NOT SPINNING DISCS AND SAYING NO DISC
When it is region lock it will say it on the display, if the player is not reading any disk, it is more likely a lens problem, see below:
Try first using a lens cleaner disk, like the ones here.
If
that does not work, the unit must be disassembled, and lense cleaned
with q tips and isopropyl alcohol or cleaning solution. See below:
How to Clean the Laser Pickup Lens on your DVD Player
How to safely clean a DVD lens?
Clean DVD lens, or replace player?
Clean CD or DVD ROM lens with a brush?
Cleaning your DVD drive
How to clean a DVD player
How do I clean my DVD player optical lens isoproponol alcohol
SOURCE: DVD not working Technika Pro 19
The failure rate on these Technika products is shocking.
My in-laws had a 19" which gave up completely just after the warranty ran out: power supply probably.
Our 15" TV/DVD now has a DVD drive failure. Just outside warranty, and on ours we hear several loud clicks.
Inspecting the slot at the side tells us that the DVD isn't spinning.
If you're lucky it's just the lens that needs cleaning, and you could use a cleaner DVD if you can get it spinning.
Or maybe it's the motor that's failed, or maybe the bearings have seized, or there's dust in there that's preventing the motor turning.
Who knows. These things are evidently not built to last. I'll not buy another.
