How to Program a JVC Car CD Player Manually
https://itstillruns.com/program-car-cd-player-manually-6371562.html
SOURCE: I NEED AN OPERATION MANUAL FOR A KD-S37 JVC RECIEVER
It is available on jvc web page. click on support and then click on user manual
SOURCE: How do I turn protect mode off of my JVC k-d s37
If you can, check your speakers and speaker wires for shorts and/or grounds. If they check out fine try resetting the radio. If there is a reset switch it will either be a small pencil tip sized depression on the face (it will not be marked) or a small hole with a red switch behind it on the subpanel behind the face. If there is no reset switch, you can reset it by disconnecting the car battery for a few seconds, or if you can get the radio out of the dash, you can unplug the wire harness for a few seconds.
