SOURCE: JBL PB10 has lost power even though still plugged in
Do you mean like the subs power lights dimming when playing it at volumes it once had no problem playing, or loss in sound, distortion?
SOURCE: Kenmore dehumidifier 580 5370 1300
There are many reasons for a dehumidifier to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
SOURCE: No power to printer even though it is plugged in
if it does not power up, then it means its having a
power problem. it might have worked fine in the past, but that's
electronics for you. Power surge, irregular power supply, excess power
supply, etc can affect the unit thereby not making it to power on.
First, check the power cord. Most times, a bad power cord causes this
kind of problem. But if the power cord is not the cause of the problem,
then problem must be from the power cord inside the printer.
This
unit must have a power supply board in it where power enters from the
mains. A capacitor, fuse, diode, etc may have been defective on the
power board and maybe that's why its not making the unit turn on. There
might also be some disconnection or something, inside the unit which is
To actually find out what's wrong, you
need to disassemble the unit with a screw driver and check what's
wrong. You will be needing a meter in order to test the components on
the power board, once you detect any bad component, you can make
necessary replacement at any electronics accessories store withing our
vicinity. This is the only way by which you can detect the problem.
Of
course, testing the power board with a meter will require someone that
has the ability. So it you can't, then you might be needing the help of a
repairman or you can call a friend that has the ability to help you
out.
I wish you the best of luck.
Regards.
SOURCE: my device won't charge
This situation sometimes occurs when the batteries get overcharged. Use the phone for a day and then attempt to charge. If it still won't charge, remove the battery for about a minute. Then re-install the battery and attempt to charge. If that doesn't clear the problem, you may need to get a new battery.
SOURCE: Milwaukee jobsite radio Cat. No. 2790-20 120V.
You might want to post this question in a different section. This is the pc laptops section.
