In order to help you turn on the oven you will need the oven manual. But as you have not provided the model number it is hard to advise which manual applies. You may want to visit this website and type the model number after you check it from the plate on the oven door. (side). AEG Service Support User Manuals
Hi, Please can you help to find a part number for outer door glass or is any other outer door glass suitable for AEG MCC3880EM I can fit in? Many thanks
Please can you help to find a part number for outer door glass , how much it would cost or is any other outer door glass suitable for AEG MCC3880EM I can fit in? Many thanks
Here is a list of oven error codes for your model Kenmore oven.
F0 indicates a Stuck key pad.
F1 and F7 may mean relay is turned on.
F2
indicates that the oven is over temperature in one of the following
modes within either cooking or cleaning mode of operation. The control
is sensing over 615 degrees with the door lock circuit in the unlock
mode. Control senses oven temperature above 915 degrees with the door in
the locked mode.
F3 and F4 indicates an open or shorted oven sensor or sensor circuit.
F5 indicates a loss of relay drive circuit.
FF indicates a loss of door motor safety switch.
FC indicates a door lock circuit problem.
If
the display of your control is flashing "F" followed by a number or
letter its a range malfunction. Press the clear/off pad. Let the range
cool for 1 hour and place the range back into operation. If the problem repeats, call for service.
Open the door to the first stop, or what is called the "vent" location. This will be about 3 inches open. Lift up on the door and pull up and out. Set the door to the side and keep the arms on the bottom in the same position, do not let them close. Clean the door, when done and set the door back in the slots the same, open the door all the way, and close it. Done. Hope this helps Fix Ya up.
Not knowing what kind of dirt or grime is on the inside of the oven, I would recommend using one of these Whirlpool products. They all work great and they have different ones for different cleaning needs. Cleaners
there will be a slight adjustment that can be done if you undo any screws or bolts holding the door , no need to take them completely out but just enough to re position the door , make sure there are no hinges that are bent .
