SOURCE: Lost the bolt/nut to my riding lawn mower!
That is a cap screw you are talking about. The size of it is 7/16" X 1-3/4". The John Deere part # is 19H2563, but I am sure you can just get one at the local hardware store. I could not find out for sure, but on most blades they use a fine-thread bolt/screw. If you can tell the difference, check before you buy, or just buy both and see which one threads in easily. Hope all this helps.
SOURCE: i need a john deere X360 44" front blade
you can buy it on ebay right now!
here's the link: http://cgi.ebay.com/John-Deere-44-Blade-X300-X304-X320-X324-X340-Ops-Manual_W0QQitemZ120402528023QQcmdZViewItemQQimsxZ20090406?IMSfp=TL090406151008r17840
SOURCE: Hello, does anybody know the torque setting for
I found the tech manual one lin but it can"t be opened since deere is updating it.I will see if we have the book"tm1974" at the dealership in the morning and get back to you.
SOURCE: torque spec on a 425 john deere head
Initial torque-115 inch pounds,final torque-186 inch pounds.Intake manifold is 53 inch pounds on all 8 screws.Valves set at 0.010 on all 4.If you go with the new style valve cover gasket {the flat one} be sure to leave the old o-ring in valve cover to keep the new gasket from splitting.
