SOURCE: Merit 725t treadmill turns on but the motor is
THIS SOUNDS LIKE A DEAD MOTOR, TRY TROUBLESHOOTING THE MOTOR BY REMOVING THE MOTOR COVER AND REMOVING THE BELTS FROM THE MOTOR THEN TRY COMMANDING THE MOTOR TO ROTATE (USING THE CONTROL BOARD) IF IT STILL SLOACHES THEN THE MOTOR IS INDEED DEFFECTIVE.
SOURCE: Merit 725T. The treadmill has
Merit 725T. The treadmill has gone into a "10 degree" incline mode on its own, and will not respond to the control panel
SOURCE: Model Pro Form 725T Treadmill We lost the key
Dear Sir:
Hello, I hope everything is right.
The best way is to buy the key from:
www.proform.com/ this is the web from the page, for your Treadmill.
The another way is to bridge the key, but I do not recommend you, since this Treadmill is very Complex equipment( computer equipment) If you do not have Experience in Electronic and Electricity you can damage the equipment.
If you need further assistance, please reach me.
sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA.C.A.
SOURCE: does the belt need to be oil merit treadmill 725t
LUBE THE DECK BELT, this produce shut down by lack of maintenance in according with the instruction manual. Maybe you have a deck belt worn.
2) Lube the rollers bearing too in according with the instruction manual.
3) Test the drive belt, and see if need replace or adjust .
SOURCE: how to calibrate merit 725T plus treadmill
please follow this steps and fix it. God bless you The
Steps for Newer Style Console Calibration: Locate
the calibration area on the rear or underside of the console (a
hole, near the console's center, that goes through to the
electronics board. (This hole should not have a screw
in it.) Insert a pencil
(eraser end), into the hole and feel around for the cal button
(will click when pressed). Press the
button 2 times (with the pencil eraser). The first click
should show CL11 in the console, the second click should
show CL21. If the process
was done correctly, and CL21 appears in the console, you are in
"calibration mode." The next few steps consists
of pressing buttons on the console and observing settings.
This will not require any other tools. Press ENTER.
CL22 should display in the TIME window and (??) in
the SPEED window. Press ENTER. CL23
should display in the TIME window and (??) in the SPEED window. Press ENTER. CL24
CL25 should display in the TIME window and (??) in the
CL26 should display in the TIME window. You should
then see the letter "E."
Press ENTER. You
should see "SS" or "55" in the console.
Push the
STOP/START button. For
safety, at this point, you should step off, or be off, the
treadmill. Push the ENTER
button. The walking belt should start to move, accelerate to maximum
speed, then stop on its own.
When the belt stops,
the incline should self test by raising to its
highest incline position, then lowering back down to its lowest
position. Once the incline
test is complete, push the POWER button 2 times. The unit should
shut off and the console should go completely blank. If this
happens, the treadmill is done calibrating and is
ready for use. If
the letter "F" appears in the SPEED or INCLINE window when
the power button is pressed 2 times, the treadmill is
indicating a failure somewhere either in the SPEED or INCLINE
(depending on the window the "F" appeared in).
Troubleshooting the failure would be the next step.
