Question about Husqvarna Garden
Husqvarna wb48s cutter belt - Husqvarna Garden
My Husqvarna Opal thread cutter is not cutting the thread from the bobbin.
Huskies are excellent machines. Guessing this is a serger? Doesn't matter. Very likely you could ask Husqvarna.com. Likely, something is a bit out of sync. Or - all sewing machines are 'picky' about being threaded correctly. You might check that.
Jan 23, 2018 | Husqvarna Sewing Machines
Husqvarna Loh 1842 cutter deck belt parts number please.
I guess you mean LTH 1842, unfortunately there is more than one length of belt on this model, we really need the pnc number and ml number found on the ser. no. plate so as to give the correct number.
Nov 30, 2017 | Husqvarna Garden
Drive belt diagram for Husky LT140 (not cutter belt)
My name is Dane and I'll try to help you with your problem. Here is the link to your operators manual. You'll find what you need on page 20. You'll need acrobat reader to see this which should be no problem. I hope I've helped. If you found this information useful, please leave feedback as deserved. Thanks! Dane
Dec 03, 2010 | Husqvarna Garden
The selective thread cutter not cutting thread.
You need a new blade in the cutter. It is a simple repair job, but needs to go to the repairman for it to be done.
Feb 28, 2010 | Husqvarna Designer I
Hi, I've misplaced my user manual for a Husky 2548xp lawn tractor. I've changed the belt for the cutters and now need to replace the drive belt. I'd like to know how to do this or receive a schematic...
Without even seeing the mower they are usually removed by loosening the bolts / nuts that secure the main cutter shaft, Look for slotted holes with bolts in is a giveaway.
Jan 20, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Have a husquvarna RB 150 and the belt that drives the cutter blades has come looose, how do i tighten
Normally there is no adjustment for a belt that drives the cutter assembly, the problem is the belt has stretched out and is no longer tight enough to engage the blade sufficintly, in which case it needs to be replaced. Hope This Helps Don
Nov 07, 2009 | Husqvarna Garden
How to fit a new drive belt
As I remember, the easiest way of removing the drive, belt,,
is too remove the tension, from the centre pulley system.
Obviously, this is done, after removing the cutter deck:)
Have fun;))
Jul 23, 2009 | Husqvarna Garden
Garden Logo
Top Husqvarna Garden Experts
Marvin
Marvin
dannydoesita
Wayne McNeil
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
