You can power scan for the code.
Turn ON the electronic device you want to program the remote to control.
Press the TV Mode button on the remote until the appropriate mode light is flashing.
Press the Power button. The mode light will stop flashing and stay lit.
Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
Press the pound key button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
Turn the device back ON by pressing the Power button.
Press sat mode key once you power back on the tv to be able to operate the receiver box.
Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
If the other buttons work you are finished.
If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Press the Mode button( sat,tv,dvd,aux) on the remote until the appropriate mode light is flashing.
You can follow the two methods I have explained below:
AUTO SEARCH FOR CODE To program your remote in Auto Search Mode, first turn on the device you wish to program and point the remote toward it.
Then press and hold the SET and POWER buttons until the LED turns on.
Then press the device key ( CATV or RCVR) .
The LED will flash once.
Then press the CH+ button.
Then hold the POWER button for about two seconds until the LED turns on. Release the POWER button and the LED will flash slowly. Your remote is searching through all of the codes. Continue to point the remote at the device until your device responds. If your device turns off, turn it back on and press the CH+ button on your remote. Then press the POWER button and CH+ button alternately until the device turns off and the code is correct. Press the ENTER button to confirm and store the code. The LED will flash three times and then turn off.
If the above is not helpful then try manually searching for code:
First, press the device button on your remote.
Then press and hold the SET button. While holding the SET button, press 1 to find the first digit, 2 to find the second digit or 3 to find the third digit.
The LED flashing time will stand for each code number. If it doesn’t flash, it will stand for zero.
For example, the TV code you are trying to find is 102.
Press the SET button and 1. The LED will flash one time.
Press the SET button and 2. The LED will not flash.
Press the SET button and 3. The LED will flash two times.
Hope it helps to find your code. Thank you for using fixya!
Sorry, but there is no simple answer to your problem. Bottom line, it needs to be repaired by a qualified technician. The blinking is a code for what circuit area of the set called for the shutdown. No matter what it is, there is nothing more you can do.
When i try to turn it on the power button flashes a code. The power button lights up once for a second, then turns off, then flashes quickly nine times and lights up once again for a second before turning off. The screen doesnt turn on at all, nor do the speakers. Any help would be highly appreciated.
Dish Netork does not have the code for Olevia but you can scan for the code using the infformation here Remote Code Power Scan
If your brand is not listed, use the following procedure to scan through all codes.
If you start the and do not press a button within 20 seconds, the remote will end the scan automatically.
1. Turn ON the unit you want to program the remote to control. 2. Press the Mode button on the remote until the appropriate mode light is flashes 3. Press the Address button. The mode light will start flashing slowly. 4. Press the Power button. The mode light will stop flashing and stay lit. 5. Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward. 6. When the correct code is reached, the device (whether a TV, VCR, or other) will turn off. 7. Press the Address button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times. 8. Turn the device back ON by pressing the Power button. 9. Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not. 10. If the other buttons work, follow the current settings procedure below to determine the current remote settings. 11. If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored. 12. The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
