Exercise & Fitness Logo
Michael Bass Posted on Jan 10, 2020
Need help troublshooting a Livestrong treadmill
johobikes
Level 1:
Habit-Forming:
Scholar:
  • Contributor 56 Answers
  • Posted on Jan 10, 2020
johobikes
Contributor
Level 1:
Habit-Forming:
Scholar:
Answers
56
Questions
0
Helped
30247
Points
80
What is the issue?
The owners manual will outline the common issues.
Live strong is Johnson Health Fitness North America product, they are out of Wisconsin.
Not much help here without a reference of the issue, try posting again with detail on changes, effects, noises
1helpful
My livestrong 10.0T starts but only runs about 5 seconds and shuts off
Check the speed senor. Align its potion or check is there is any dust accumulated on it,
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
The console does not power up...I reset the reed sensor to go closer to the magnet, still does not get power. Is there something else I can try
Trouble Shooting Treadmill with No Power - YouTube
? 1:23
https://www.youtube.com/watch?v=N6Yg5S0WML8
Jan 20, 2011 - Uploaded by WilkinsFitness
Trouble Shooting Treadmill with No Power ... Disconnected wiring harness at console can also cause no power as well as faulty harness.
Troubleshooting a Treadmill That Won't Start - Livestrong.com
www.livestrong.com > Sports and Fitness
Jun 6, 2015 - If your treadmill doesn't start, you will need to troubleshoot the possible cause. ... If your treadmill is not properly plugged in, power surges and fluctuations in your ... If the console lights up, but the treadmill won't start, the motor ...
How to Determine If a Treadmill Console Is Broken ...
Treadmill will not turn on
I am unsure about your personal treadmill, but, have you started with the easy things:
Check that the cutoff cable is in place?
The contacts (if it has them, some are magnetic) of the cutoff are clean and free to connect?
If they are ok, does it sound like the motor is trying to turn?
Are there any burning smells?
Have you checked for a motor fuse in the treadmill itself?
I hope that gets you a little closer to finding the problem.
Edit, i didnt see the full question, sorry. Sounds like there is a motor fuse gone.
I have found the service manual here if you need it:
https://www.manualslib.com/manual/1047819/Livestrong-Ls8-0t.html#product-LS13.0T
What can be done when the track slips on my treadmill?
there should be two screws one on each side of the belt in the back of the treadmill (you may need to remove the side rails (theres one on each side of the belt) to see them) those screws will tighten the belt. note: you must be carfull that the belt is tightened evenly. livestrong.com is a great website if you need help wih this. good luck!
Top Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
