Check the bottom of your laptop for a Windows label. the version of Windows will be printed on this label and the product installation code. This means you have a legal Windows operating system and all you need to do is to borrow this version of Windows installation CD from a friend to install Windows on your Acer. I suggest you make a copy of this Windows installation CD. After installing Windows you need to install the laptop's device drivers. You can also get a Recovery CD from Acer for your model Acer laptop. This will have Windows OS as well as the laptop's device drivers.
Download the device drivers from the Acer WEB site. Make sure you select the model of your laptop the drivers you that require that matches the Windows version that is installed on your laptop. Use this link to get to the Acer support: - http://www.acersupport.com/drivers_download.aspx
I think even with the FKey you're likely to be asked for the password. This is one of the things that makes me hate erasing Acers.
Order a free Ubutu disk. While waiting for it google acer factory password ubutu. The disk can be used to view passwords, but it's a bit technical.
This one issue makes me hate Acer!
(What are the manufacturers thinking! Nobody writes passwords down when they get a new toy! Even if they did, they've always lost it by the time the thing needs to be erased. Enough rant!)
you will need to access the setup page of the router and check the wireless settings manually. On the wireless tab you will find the WEP WPA network key
To delete the Acer Aspire Notebook HDD user password, go to http://www.unlockbiosrecovery.com/Unlock_Acer_HDD.php
The link above will show you to enter 3 wrong password and then copy down the 5 or 8 digit code it displays with Disabled message. Purchase the Acer HDD master password from the link above and submit the code and your model and they will email you the bios master password to unlock your Acer HDD in an hour.. They guarantee it to work or your money back and I have used them successfully dozens of times, saving me a ton of time and money.
not only do you need to remove the comos battery you have to short out the posts the battery connects to this will remove remaining power stored in any caps connected to the comos circuit after about ten minutes this should clear the comos remove battery unplug charger and remove comos battery the short the comos battery socket. there is still some voltage on the board stored in the capactors this will keep the comos in memory even with out the battery.
