SOURCE: DELTA MODEL 470-WH LOW WATER FLOW AT KITCHEN FAUCET
This could be a couple of things.
If you need a diagram of the faucet with part numbers here is the link:
Delta 470
Hope this helps!
SOURCE: grohe pull out kitchen faucet the inner tube ripped
go to the store you bought it and see if they carry parts. if not , try the internet under grohe.com.
SOURCE: I have purchased a Tuscany Brass kitchen faucet
if i remember correct this connection is plastic to plastic,if this connection is broken you must replace the hose and the head.i hope this helps.good luck with you project.
SOURCE: kitchen faucet leaking pull down sprayer spout type
try tightening the nut that attaches the flex line to the pull out spout
SOURCE: kitchen faucet single handle pull-out. The base of
I have the same problem with an American Standard Reliant Kitchen Faucet that wont swivel anymore. I called American Standard and they are sending me the replacement parts to fix it free of charge, I have had mine 6-7 years and they said it was under warranty. Call 800-442-1902. Good Luck
