Sounds like your hard disk drive has died.
Fit a new SSD (solid state drive)
Did you make a boot disk / thumb drive like Toshiba recommends?
After you fit the new SSD run the boot disk.
No boot disk you will an O.S. to load onto you computer.
To run the boot disk you have to get into setup, press F2 when the computer starts.
Look for the boot disk options, if you are using Thumb Drive switch the boot option to USB.
If you are using a CD switch the boot option to CD.
Close the setup and reboot...
The boot disk will set up the Operating System with the usual questions.
Hope this helps
Geoff
SOURCE: no bootable divice please restart system
this screen appears when
hard drive has been removed, dislodged or stop working
to rule out the 1st two options
if your technical enough
turn power off remove charger and battery from laptop then try to reseat the hard drive
