SOURCE: clean condenser coils
Its not easy but a flexable vacume hose would help. and aslo you can take the end peice off and try to get it from the inside to. Good Luck
SOURCE: how do I get to the coils on my Amana ARB1914 to clean them?
youll need to use a refrigeration coil brush, similliar to this http://www.repairclinic.com/SSPartDetail.aspx?PartID=12859&Acc=1&PPStack=1
SOURCE: amana side by side coil cleaning
removethe lower kickplate , under the doors, then with a refrigeration coil brush(avaailable at te hhradware stores) and a vaccumm you can clean the coils
SOURCE: makinga chirping sound does not produce any
MAKE SURE THERE IS NO ICE FORMING ON COILS IF U CAN SEE THEM. IF IN BASEMENT,
SURROUNDING TEMP MUST BE ABOVE APPROX 60 DEG. ALSO, TRY ADJUSTING THERMOSTAT
SOURCE: evaporator coil freezing, replaced main control
It is possible you have a defective fan motor in the condenser area or evaporator area. Sometimes when they become defective they will run for a while and just warm up and stop while the compressor continues to run. I learned that one on four costly returns to the home. The cost was to me not the customer. Thanks, Sea Breeze
