SOURCE: installing after market stereo
Dave,
You will need to go buy a wiring harness adapter from your local Walmart (usually cheapest there) or Local Electronics place (ie Best Buy). The wire harness that goes out from the radio goes into the Adapter and the adapter plugs into the car harnesses. Also these Adapters come with the wiring diagrams for your vehicle. They typically run 10 - 15 bucks depending on where you get them. Thanks for using FixYa!
Sincerely,
JC
SOURCE: Amp powers on but sub does not come on
I would double-check your RCA's on the amplifier. You should hear a thud if you unplug them. If not they are either not hooked up or defective.
SOURCE: how would i add amp and sub to a factory stereo system
you have to goto best buy wal mart or somewhere like htat they sell an adapter that converts speaker wire to rcs its like 20 to 30 bucks what i did is take the left rear speaker and direct wired it to the right side then conected the converter box to the left rear wires and then you can go from there with your rcas
SOURCE: need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
http://technoanswers.blogspot.com/2012/01/radio-goes-on-and-off-while-driving.html
Cigarette
lighter, Remote central locking, and Radio stopped working
http://whoisbyme.blogspot.in/2012/07/cigarette-lighter-remote-central.html
VW passat radio off safe
mode? VW radio CODE?
http://schematicsdiagram.blogspot.in/2012/03/vw-passat-radio-off-safe-mode-vw-radio.html
How to wire new Radio on
1990 Toyota Celica?
http://schematicsdiagram.blogspot.com/2011/12/how-to-wire-new-radio-on-1990-toyota.html
Radio Stereo Wiring Diagram
for 1991 Chevy 1500?
http://schematicsdiagram.blogspot.com/2011/12/radio-stereo-wiring-diagram-for-1991.html
How to remove radio on
Acura Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-radio-on-acura-car-models.html
Where is Radio Fuse located
on 2007 Dodge charger?
http://schematicsdiagram.blogspot.com/2011/12/where-is-radio-fuse-located-on-2007.html
How to reset Radio code
after car battery is died?
http://howtobyme.blogspot.com/2011/12/how-to-reset-radio-code-after-car.html
Can car radio code block
Passkey anti theft system ?
http://schematicsdiagram.blogspot.com/2011/12/can-car-radio-code-block-passkey-anti.html
After Market Stereo wiring
for 1999 Chevrolet Silverado 1500?
http://schematicsdiagram.blogspot.com/2011/12/after-market-stereo-wiring-for-1999.html
Chevy car radio doesn't
allow to switch to the XM Band to get the radio ID?
http://schematicsdiagram.blogspot.com/2012/01/chevy-car-radio-doesnt-allow-to-switch.html
No power to radio on 2005 Toyota Scion Xb?
http://repairhelpcenter.blogspot.com/2012/01/no-power-to-radio-on-2005-toyota-scion.html
Lexus rx330 Radio has power but no sound?
http://repairhelpcenter.blogspot.com/2012/01/lexus-rx330-radio-has-power-but-no.html
Lincoln Town Car Radio stereo
wiring?
http://technoanswers.blogspot.in/2012/02/lincoln-town-car-radio-stereo-wiring.html
Radio wiring diagram for 1997 Lincoln Town Car?
http://technoanswers.blogspot.in/2012/02/radio-wiring-diagram-for-1997-lincoln.html
How to remove cd player from dash on 2003
Lincoln Aviator
http://technoanswers.blogspot.in/2012/01/how-to-remove-cd-player-from-dash-on.html
These details will help you thanks.
Hi ,this is shenzhenelectronic.
Our website is http:// www.shenzhenwholesale.com
we have some electronics ,for example Microsoft Xbox360 Live card 10000 US Points,Moster beats by Dr.Dre solo hd,Moster beats Dr.Dre pro and so on.
Welcome to visit our website
http://www.shenzhenelectronic.com/monster-beats-by-dr-dre-solo-hd-headphones-black-red-white-hot-sell_p53915.html
http://www.shenzhenelectronic.com/brand-new-monster-beats-by-dre-pro-headphones-in-white-black-5pcslot-hot-selling_p53932.html
