Home Security Logo
Kash Wickramasekara Posted on Jan 09, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Rest button for Sandleford gem safe stuck and not coming out. Can't reset. What to do?
Geoff
Level 3:
  • Master 562 Answers
  • Posted on Jan 09, 2020
Geoff
Master
Level 3:
Answers
562
Questions
0
Helped
179001
Points
1681
Have you tried grabbing the button with your fingers and pulling it out?
I had a look at the Vimeo set up video, it looks like there is enough button sticking out to let you do that.
Is it a new safe by any chance?
Return under warranty?
perhaps a squirt of electronic component cleaner might help..
Regards
Geoff
3 Related Answers
Anonymous
  • 25 Answers
  • Posted on Feb 18, 2009
SOURCE: radio rest buttons to reset code
What model stereo is it?? concert, gala
Anonymous
  • Posted on Jun 28, 2011
SOURCE: cant open Sandleford Garrison Safe N15115
I have a new N15115,ES20 electronic safe,it will not accept a change of password.when new password entered it only beeps once ???
claudeinmo
Claude Kayser
  • 9098 Answers
  • Posted on Dec 05, 2015
SOURCE: How to reset the numerical code on my Sandleford Titan digital Fireproof safe No12799145
Reset digital combination to sandleford titan digital fireproof ...
www.fixya.com/support/t22206416-reset_digital_combination_sandleford
Dec 15, 2013 - reset digital combination to sandleford titan digital fireproof safe - Sentry Fireproof Safe ... someone might have known the code and changed it.
Lost instructions for sandleford E.S.20 safe - Fixya - - Forum
Sandleford N15115 in locked position but with door open. No key or combination. How do I reset combination?
Install fresh batteries.
Press reset button on left side of door (may be covered with protective plastic cap), beep will sound.
Enter new 3-8 digit code, press * or # key, green light will come on to confirm new code accepted.
Manuals are available at https://www.sandleford.com.au/sandleford-manuals
1helpful
Sandleford es20 safe won't open
Find something long & thin, I used a screwdriver. Has to be at least as long as depth of safe. There are 2 holes in the back of my sandleford ES 20 safe. Insert screwdriver into hole on left & push in until it hits the door on the other side. You have to do the next bit blind, but feel around for reset button. Once you find button use screwdriver to press. Lock will beep & you then just have to put your new code in. Problem solved. Of course this method only works if there is nothing inside the safe getting in the way of access.
Once inside remove anything valuable & find somewhere secure to keep it. This method took about 30 seconds to gain access. I'd hate to think how quick a professional thief could open it.
24helpful
3answers
Reset n15115 sandleford safe
i forgot my combination to my 15115 sandleford safe how do i open it
2answers
I have a sandleford safe es23 if i punch the code in the safe beeps until i open it with the keys and disconnect the batteries. What am I doing wrong
we are looking after a friends place with one of these safe's in them, my daughter has pushed buttons and it wont stop beeping, we dont know the code or anything?? how do i stop it beeping??
9helpful
4answers
54helpful
3answers
Changing the code on standleford es20 safe
If the problem is that the safe is not accepting your pin code, try first code 159A, or 159B that are default codes to open the safe.
If you have the sentry key, open with key, and there is a red button inside the door to reset the code.
If you have no key and default code does not work, call sandleford number at 03 97750699 they will guide in opening the safe.
226helpful
11answers
Sandleford electronic safe es20
have just had the same problems if you had the key there is a red button inside the door to reset the code but obviously no key no red button I have the sandleford number to call 03 97750699 or try the factory pre set 159 A or B see how you go
Top Home Security Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Home Security Expert? Answer questions, earn points and help others
