SOURCE: jenn air refrigerator temp gauge problem
Hi again,
In your particular model I believe it is termed as "MaxCool".
It is also possible that the sensor for the refrigerator is covered by
a food item and therefore was getting erroneous readings hence cutting
off early (making the temp go higher than normal). Based on this, you
can try switching the food items around relocating them as to how they
were placed inside. Incidentally, frequent opening and closing of the
refrigerator of course would be exposing the inside to warmer air
making the unit work harder.
The reset requires that the unit be
unplug for an hour or more hence my suggestion during the Live Session
to make use of a second refrigerator while checking out the Jenn Air.
SOURCE: Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
SOURCE: Refrigerator not cooling although lights and sound are OK
your condensor had been chocked therefore the gas is not circulating. contact your service authority..... as because it cannot be done by your self.
SOURCE: I have a Kitchenaide side by side refrigerator thats not cooling.
Check the coils underneath the fridge. Check the coils in back if accessible. Clean the coils if covered in excessive dust it may help. Make sure the vent on fridge side isn't blocked or plugged.
SOURCE: Samsung French Door Refrigerator not cooling
it's only 4 weeks old ./ don't mess with it it has a warranty you may void it if you work on it . it is probably in the main digital control in th fresh food .. but i would call the seller and they can set up a service for it .. mm
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
