Question about Sony Televison & Video
I replaced the fan on my 55" Sony Projection TV , after it was blinking a red light 4 times and woukd not come on. Isnt it suppose to come on when you turn the tv on to keep the blub cool?
5 Suggested Answers
TVtechmaniac
David Makowski
  • 140 Answers
SOURCE: 55 in Sony KDF55WF655 Goes to standby and red light blinks 4 times
Check the thermal sensor fuse part# 1-910-023-93 or possibly one of the four fans. If the unit goes into Fan/Thermal Protect shutdown (4 blinks) it can be difficult to determine the cause since the unit turns off too quickly to troubleshoot. Solution: Ground the data line by inserting a jumper between pins 3 and 6 of CN44 on the H4 board. This overrides the protection circuits for troubleshooting. Do this right after turning the unit on and as soon as the lamp is seen lighting. Check pins 2, 5, 8, and 11 of CN6000 on the G2 board for less than 1VDC. Any voltage higher than that indicates a faulty fan. If all voltages are within specs, the H4 board must be replaced. If a fan is found defective, the optical block will need to be replaced if it is located inside the assembly. H4 Board Part Number: A1054674A Replace the following part based on which pin of CN6000 is out of specs: Pin 2: Fan 1 (part of optical block) Pin 5: Fan 2 178723211 Pin 8: Fan 3 178706511 Pin 11: Fan 4 178708111 Optical block Part Number: A1084662A
Posted on Aug 26, 2007
Anonymous
  • 239 Answers
SOURCE: Sony KDS-60A2000 projection TV: power led blinks 4 times
the projector bulb has gone out you need to replace it.
hope this helped
please rate well
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
Posted on Mar 04, 2009
Anonymous
SOURCE: TV Wont turn on - Red Blinking Light under Lamp
The lamp is shot. Port is on the right side of set - just remove and take a look. Check VISA limit.
Posted on Apr 16, 2009
Anonymous
  • 178 Answers
SOURCE: KDS-R60XBR2 power led blinks 4 times,
There are three fans the one that usually fails is located on top of the optical block and cannot be reached by the owner unless you take the set apart yourself. What is happening is that one of the fans are not spinning fast enough or has stopped altogether. The best solution is to replace all three fans cleaning may not be enough to get a slow fan up to speed, and the tech should blow out the dust in the duct work. This is what the tech coming out will (or should) be doing. Also some fans will have an intermittent startup, and cause this intermittently, so it is a good idea just to replace the fans instead of just cleaning them.
Posted on Sep 02, 2009
jango2
Jango Fixit
  • 38 Answers
SOURCE: kdl55ex710 sony tv red light 7 times blinking
Sony Bravia 7 blinks disclosure
https://www.facebook.com/photo.php?fbid=711021065598851&set=a.103481003019530.7279.100000728915080&type=1&stream_ref=10
Posted on Jan 09, 2014
The light blinks red continuously on my kdf55e2000 sony tv
Hello, does it blink in a pattern (example:blink 4 times pause and repeat 4 time blink)? Please let me know. tks
Nov 01, 2013 | Sony Grand WEGA KDF55E2000 55" Projection...
I have a sony 55"
3 times red standby light flashing indicates that lamp cover (first thing that you removed from tv to replace lamp) is not fixed properly on tv, make sure lamp cover is attached correctly with tv to solve this issue.
3 times blinking is not problem of fan or anything else, it is related to lamp cover that engages safety micro switch inside to turn On tv.
Thanks.
Jan 27, 2011 | Sony KDS55A2000 55" HDTV
Tv won't turn on 4 blinking led
Red led blinks 4 times is an error code that shows that fan is not running in tv, check fans connections and make sure all are plugged properly.
Thanks.
Jul 18, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Tv will not turn on red standby light blinks 6 times
tv will not turn on red standby light blinks 6, on a sony grand wega kdf-55xs955 55 in. rear projection hdtv television
Jun 19, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony Wega Tv powers on w/ green power light and
need to know how many time the red light is blinking there should be a pause. 4 blinks is a fan, 3 blinks is the lamp door is not closed 6 blinks is thermal sensor.
Apr 22, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony KDF-E50A10 No Picture
4 times blink error shows that any FAN is not running in TV as there are 4 fans in this TV.
Please check fan connectors and make sure all are plugged securely.
Feb 13, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Kds55a2000 red light flashing
The SONY Owner's Manual for the KDS55A2000 does not state what the 4 times blinking Power LED means.
However, my Sony Extended Care Service support insists that the projection lamp is the cause for the 4X blinking LED
Power light.
I do not agree but am forced to buy a replacement lamp (not cheap) to prove that the problem is probably the fan, as the TV Technician states elsewhere in these FixYa support questions and answer
Nov 10, 2007 | Sony KDS55A2000 55" HDTV
Aug 26, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Tv will not turn on
4 blinks is a fan error. most of the time its th main fan on the back. blow the inde of the fan out with dust. if this dont work you will need to replace the fan
Aug 14, 2007 | Sony KDS55A2000 55" HDTV
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
