Hi Ann-
I found this link regarding your Sony Bravia RM-YD028 remote control.
https://www.remote-codes.com/brands/sony/RM-YD028.pdf
I also found this youtube video on using the SYNC MENU function on your remote. Other devices need to be connected via HDMI cables in order to use this function..
https://video.search.yahoo.com/search/video;_ylt=AwrC5rLYtBZejHkARJX7w8QF;_ylu=X3oDMTBncGdyMzQ0BHNlYwNzZWFyY2gEdnRpZAM-;_ylc=X1MDOTY3ODEzMDcEX3IDMgRhY3RuA2NsawRjc3JjcHZpZANBSjZmSlRFd0xqRWdxQVZtWGhacUFBWm5NVGd4TGdBQUFBRDQuS2NLBGZyA3lmcC10LXMEZnIyA3NhLWdwBGdwcmlkA0FDbXY4clZRUTdpM1o3ZFZibk5sVEEEbl9yc2x0AzYwBG5fc3VnZwMwBG9yaWdpbgN2aWRlby5zZWFyY2gueWFob28uY29tBHBvcwMwBHBxc3RyAwRwcXN0cmwDBHFzdHJsAzQwBHF1ZXJ5A3NvbnklMjBicmF2aWElMjBybSUyMHlkMDI4JTIwc3luYyUyMG1lbnUEdF9zdG1wAzE1Nzg1NDY2NjY-?p=sony+bravia+rm+yd028+sync+menu&ei=UTF-8&fr2=p%3As%2Cv%3Av%2Cm%3Asa&fr=yfp-t-s#id=1&vid=e91cde4e74ec57e7f75683e6ba121b47&action=view
Hope these help.
SOURCE: programming remote to operate Sony Bravia TV
You can find your codes here:
www.tvcodes.com
OR
www.remotecodelist.com
OR
www.remotecontrolsrus.com
SOURCE: MY Sony Bravia remote control
ebay is your friend.
--- Please dont forget to vote if you liked my answer thanks
SOURCE: I have two near-new 32 inch Sony flat screen TVs
Hi Bob,
Clean/wipe the infrared reciever of the your TV with soft clean cotton cloth. I've suspected that there's an obstruction from the infrared reciever. Best that you have to clean it also inside but the problem is if you can't dis-assemble the unit. If the symptom persist, your infrared reciever circuitry is faulty(needs to look for a qualified technician to troubleshoot the problem).
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
SOURCE: I have two Bravia TV's
The infrared sensor on the tv is probably bad. Or make sure nothing is blocking the sensor on the tv. The remote is line of site. Hope this helps.
SOURCE: My RM-YD028 Sony BRAVIA Remote
Remove the batteries from the remote and wait 5 minutes or more. After waiting, insert the batteries again. The remote should now work. If it's still not working, the remote is probably defective. If that is the case, please contact Sony Customer Support, which will be able to assist you in getting a replacement issued.
thanks
