SOURCE: I have to change spark
Follow the spark plug wires into the engine area. Usually spark plug wires are simply pulled from the plug(s). Grasp them by the boot that is closest the plug. A spark plug wrench socket on a ratchet wrench will be needed and there several sizes of plug. Loosen the plug counterclockwise, remove it. Check and adjust the gap on the new plugs, thread the new ones in by hand then tighten with the wrench firmly and push the plug wires back on tightly.
Good Luck,
Gary
SOURCE: Can I charge battery while still hooked up? 2010 polaris sportsman 850 tour eps
positive to positive , negative to negative should be no problem
