SOURCE: grinding noise when washer starts
hi there,
the grinding noise may be coming from either the pump or you have something caught between the drums.
the f-33 error is the pump drive system error. it indicates that you have lost communication between the CCU board and the pump. the CCU board is the main control board that you see in the front of your washer.
i would recommend that you call a technician to check it out, as you will have to do some checks that require technical knowledge.
SOURCE: want an owner manual for an old Kenmore 70 series
Go to managemylife.com and type in the model number you provided under the "Manuals" link. Your owner's manual is listed in a .pdf (Adobe) format that you can download or print for FREE. I hope this helps you.
SOURCE: we have a kenmore elite washer mod. 970-c40062-00
Your Stainless Steel drum is supported inside of the washer tub by a spider assembly. The assemply, which is made of cast aluminum, has corroded (steel and aluminum and detegent don't mix) and the spider assembly has broken. The drum has likely wobbled enough to wear a hole through the tub. You need to replace the drum and spider assembly, and tub.
SOURCE: User manual for Kenmore dish washer Mod#665.13842K601 Type 575-0
You can download th manual for free at the following Kenmore Support link
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0608085.pdf
