Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. https://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. If blinks continue without any pause, the main board is faulty.
SOURCE: Mitsubishi WD-62525 Red Status Light After Cap Replacement
which caps did you replace? As the normal repair for the first generation dlp is to replace the (4) 1000 uf caps. the (2) 2200 uf caps and the (2) 3300uf caps on the power pwb when you get the 34 error code.
SOURCE: flashing status light
Wow I may have just fixed the flashy yellow status light problem. It's so siple yet so difficult. Looking at the front of your T.V. on the left hand side bottm there is a door for a filter. SMACK IT. if the door isn't shut all the way that status light will flash. Mine is turning on now, just have to work on the major problem now :) Hope you have the same simple problem.
SOURCE: Mitsubishi WD-73732 TV
It could be a bad lamp but I've run into many of these TVs with bad color wheel assemblies. Also, if you are getting a dialog box coming up with these words," airflow blocked, TV will shutdown ..." that's a defective thermal fuse.
This is a job for a mitsubishi authorized service center. A tech can disassemble the light engine and confirm that the wheel is the problem. If you're still in warranty, great. If you're only recently out of warranty, call mitsubishi for assistance. Remember that persistance pays off when dealing with large corporations. You very seldom get what you're looking for on the first call or from the first person you speak to.
michtech
SOURCE: Mitsubishi XD510U Status light is blinking
Page 30: replace the lamp (Page 25)
Spare lamp for XD510U/XD510U-G/SD510U: VLT-XD510LP
http://www.retrevo.com/support/Mitsubishi-XD510U-Projectors-manual/id/15978dj994/t/2/
