Question about Husqvarna Garden
Which husqvarna 18" bar will fit poulan pro pp4620avx??
    Top Expert:
  • Husqvarna Master
  • 34,536 Answers
Most saw bars are interchangeable compare them before you install it...ok so go find yourself a chart then...good day to you
Posted on Jan 07, 2020
  • Joshua R Edmondson Jan 07, 2020
    That was not helpful at all... very few will actually crossover. Poulan is made by husqvarna, so I know that they have bars that fit both. Cross reference chart would be awesome but can only find Oregon bar cross over charts
Anonymous
SOURCE:
Anonymous
  • 44 Answers
SOURCE: Bar sprocket smokes, gets hot spot
Sounds like you're not getting enough oil to the chain. Basically you've got an oil pump, pickup and filter involved in getting oil from the resovior to the chain/bar. If you cleaned the obvious area and the chain is not coated with oil, you may have a clog further up (inside) the oil delivery mechanisms. Also, drain the oil from the tank, and see if you can "blow" air through there. With the saw running & pointed down, you should be able to see oil on the ground being slung off the chain, if not, you are not getting enough oil to the chain.
Posted on Nov 29, 2008
Anonymous
SOURCE: poulan pro with tooless chain tightening - chain will not stay on
i have a 4620 poulan that had the same problem. use it for 10 minutes, spend 15 minutes reinstalling the chain. i sent poulan an email threatening to sue them and they decided to send me the parts to change it over to the old style for free. try poulan.com
Posted on Apr 27, 2009
Chuck Bamforth
  • 205 Answers
SOURCE: Poulan Pro 42cc Just Won't Cut It
The chain is directional, only cuts one way. If a new chain won't cut, it must be on backwards.
Posted on Apr 28, 2009
Beerm0nster
  • 82 Answers
SOURCE: What size chain does the Poulan Pro 4218 use?
It is an 18" chain .The user manual is at http://www.chainsawsdirect.com/manuals/PP_3516_4218_Man.pdf
On page 6 the part numbers for the bar and the chain are shown
Hope this helps .. if so, pls leave feedback, if not - let me know!
Posted on Jan 25, 2010
dontbother10
dontbother10
  • 2220 Answers
SOURCE: Poulan Pro Chainsaw chain tensioner is junk
Hammy if you scream loud enough Poulan may foot the bill for this.
Poulan “PP4620AVX” IPL (exploded parts list)
We are going to replace this page 2; item 70
http://weborder.husqvarna.com/order_static/doc/NIUS/NIUS2009/NIUS2009-PP4620AVX-545103410-952802169.pdf
Poulan “PP4620AVHD” OM
http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2005/NOUS2005_545047502.pdf
Poulan “PP4620AVHD” IPL
http://www.ordertree.com/modelinfo/PWE/PP4620AVHD-Gas-Saw/75.PP4620AVHD-Gas-Saw.1.59.1.html
With this; “Handle, Chassis & Bar Assembly” print; item 67; ChainBrake Assembly; $21.83.
You also need;
  • Item 68; Bar Mounting Nut; $0.56 each (need 2) and
  • “Engine Assembly” print; not illustrated; part number 545006011; Scrench; $9.75.
This is the configuration professionals have used forever. The only thing to remember here is to hold the nose of the bar up when adjusting and tightening the bar nuts.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Posted on Apr 18, 2010
Testimonial: "Thanks -- that's exactly what I was hoping to find. It's wonderful to be able to tap into expertise like this. Very Happy!"
Poulan pro troubleshooting
CHAIN STRETCHS AS IT HEATS - KEEP CHAIN TIGHTENED CORRECTLY AND ALWAYS KEEP OIL IN OILER AND MAKE SURE IT OILS THE CHAIN. IF THIS DOESN'T FIX - REPLACE THE CHAIN. IF IT STILL HAPPENS THEN REPLACE BAR. WILL FAIL AGAIN WITHOUT OIL. POULAN WILL NOT HOLD UP WITHOUT CHAIN LUBRICATION. WORSE THAN OTHERS. IF CHAIN OR BAR OVERHEATED YOU'LL WORK ON IT MORE THAN YOU CUT. OIL IS THE KEY TO CUT WITH A POULAN!
Aug 10, 2014 | Poulan Pro PP4620AVX 46cc Gas Chainsaw...
Where to buy parts of poulan pro pp4620
i find gong threw sears parts online is the easiest
Aug 09, 2012 | Poulan Pro PP4620AVX 46cc Gas Chainsaw...
What size of chainsaw file do I need for poulan pro PP4620AVX
hi there susan brown6
if your chain is a 3/8 lo pro chain the file will be 5/32nd ------- and if its a 0.325 size use a 3/16th file -------- or if its a 3/8 -0.58 chain use a 7/32nd file
but its more likly to be either 5/32nd( for 3/8 low pro chain ) or 3/16 th for .325 chain
cheers
pauly46
Sep 10, 2011 | Poulan Pro PP4620AVX 46cc Gas Chainsaw...
I would like to see part digram? for poulan PRO 20"
Poulan currently offers 2 46cc 20" bar chain saws which are virtually identical
model PP4620AV, and PP4620AVX
http://weborder.husqvarna.com/order_static/doc/NIUS/NIUS2009/NIUS2009-PP4620AV-545014314-952802075.pdf
if you are looking for a different diagram please include the model number you need in the post.
Thanks
Dec 28, 2010 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro Chainsaw chain tensioner is junk -- chain now goes from tight to falling off in 1 cut. Model PP4620AVX. Looking for more foolproof mechanism!
You also need;
Lou
Apr 18, 2010 | Poulan Pro Chain Saw 46cc 20"
Need chain adjustment wheel part # for poulan pro model pp4620apx chsain saw
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
I think this is the what you seek:
http://www.ordertree.com/modelinfo/PWE/PP4620AVX-Gas-Saw/75.PP4620AVX-Gas-Saw.1.59.1.html
The "Handle, Chassis, and Bar Assembly" detail
Items 63 through 69 are parts, I think item 70 is a complete assembly ($22.78 without a kiss).
Your saw without tooless adjustment.
Item 64 (complete assembly) $2.53.
If my saw I'd ask if it can be modified!!!
http://www.ordertree.com/cms/parts-lookup-help/73.html
I suspect a vert simple modification. HTH
Lou
Nov 18, 2009 | Poulan Pro Chain Saw 46cc 20"
Oiler on saw not pushing oil as fast as gas is there an ajustment screw or is it automatic and just needs to be cleaned
Your Operator's Manual does not address any oiler adjustment; an IPL for for your saw lists no oil adjustment screw.
Operator’s Manual
http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2006/NOUS2006-PP4620AVX-952802146.pdf
IPL
Given the above I would conclude your saw has no operator adjustable oiler. If you think oil output is inadequate contact Poulan here:
Poulan.com
http://www.poulanpro.com/node4033.aspx or phone them
Handheld (Chainsaws, Trimmers, Blowers, Edgers)
1 (800) 554-6723 (Please have your saw within easy reach)
HTH
Lou
A shorter bar will oil better. with no adjuster I recommend you not go longer. If the bar is getting hot make Poulan repair it under warranty!!!
Nov 17, 2009 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
35 people viewed this question
Top Husqvarna Garden Experts
Marvin
Marvin
dannydoesita
Wayne McNeil
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
