Scala ic5 download software?
(If you don't have it installed, download Java here.) ... This lets you run single-file Scala programs in your browser using Scala.js, including graphical/interactive ...
First, make sure you have the Java 8 JDK installed.
To check, open the terminal and type:
java -version(Make sure you have version 1.8.)
Then, install Scala:
...either by installing an IDE such as IntelliJ, or sbt, Scala's build tool.
or
Best if you prefer a full-featured IDE (recommended for beginners)
DOWNLOAD INTELLIJ
·Getting Started with Scala in IntelliJ ·Building a Scala Project with IntelliJ and sbt
·Testing Scala in IntelliJ with ScalaTest
Best if you are familiar with the command line
DOWNLOAD SBT
·Getting Started with Scala and sbt on the Command Line ·Testing Scala with sbt and ScalaTest on the Command Line Compared to other programming languages, installing Scala is a bit unusual. Scala is unusual because it is usually installed for each of your Scala projects rather than being installed system-wide. Both of the above options manage (via sbt) a specific Scala version per Scala project you create.
But it's also possible to "install" Scala in numerous other ways; e.g., grab Scala binaries and use Scala from the command line or use Scala in your browser!
