Question about Whirlpool Washing Machines
My whirlpool expert 14kg is stuck on soak, even when i spin the nub to wash... can i please have a solution
Anonymous
SOURCE:
kakee
Michael Galve
  • 1269 Answers
SOURCE: Whirlpool AWM 6145/3 gets stuck
That's a timer problem. Check on the user's manual on how to reset the timer settings. The timer can be replace if found defective but you need a pro technician to do it.
Posted on Aug 29, 2008
Anonymous
  • 333 Answers
SOURCE: i have run the machine on a daily wash
It sounds like your water discharge pump is either clogged or not working to full capacity. You can check this by looking at or feeling your discharge hose during drain and spin to see if the water is actually draing fast or just dribblig. If this is the problem then call a teck or change the pump yourself. If you do it yourself please unplug your unit before working on it. I hope this helps you.
Posted on Nov 23, 2008
Anonymous
  • 20 Answers
SOURCE: washer will not spin, will not spin in any spin cycle
Your water pump is clogged
Posted on Feb 10, 2009
Anonymous
  • 236 Answers
SOURCE: My washing machine won't spin!
as with basic spin faults -a number of reasons usually 1 motor brushes, 2 motor 3 motor control pcb or the obvious one - the belt has come off.
Posted on Mar 13, 2009
Anonymous
  • 100 Answers
SOURCE: spin cycle not working,
sounds like you have a broken motor coupling between the motor and transmission
Posted on Mar 30, 2009
How do I incorporate a soak cycle into a wash/rinse spin cycle in a whirlpool 9kg toploader **********00
You may be able to let it fill, then turn it off and allow contents to soak. After soaking, you can turn it on again to complete washing.
Mar 14, 2018 | Whirlpool Washing Machines
Whirlpool Cabrio Washer does not spin the water completly out of the clothes
probably not getting into high speed spin mode
they spin slow in the initial stages to allow the clothes to become evenly distributed then after the water is removed they pick up speed
It is possible a problem in the program board not advancing to high speed
Call in a technician for a proper diagnosis and a quote
Jul 07, 2016 | Whirlpool Washing Machines
Washing machine will not drain water
Here are some basic troubleshooting steps you can follow to help you determine why your washing machine won't drain:
1. Check the drain hose in the back of the machine and make sure it isn't kinked or flattened.
2. If it spins but won't drain, there could be a piece of fabric stuck between the inner and outer tub, or even the drain hose or pump itself. The farther into the machinery a clog goes, the trickier it can be to remove. It could also be a faulty timer.
3. Are clothes soaked at the end of the wash, even though it appears to go through the spin and drain cycles? Worn or loose belts could be the culprit.
4. When the spin cycle starts, do you hear a humming noise? It could be a faulty or jammed impeller pump.
For more suggestions on troubleshooting and fixing this issue, check out Washing machine not draining. I hope this helps!
Sep 11, 2012 | Whirlpool Washing Machines
Whirlpool awo d 4305 s draining problem clothes left soaking
Ok, replaced waste pump - slight improvement but clothes still bad... only just seen your solution Mike!!! I didn't even notice a spin control board there, I will check/swap it tomorrow as I've only just put everything back in place(incl. kitchen cupboards etc!).
Is this a common problem with this model?? There's a mountain of appliances near where I work and I'm free to take whatever I can find, I'd say some people just buy a new machine without even checking if the filter's blocked looking at some of these appliances!
Thanks all!
Aug 22, 2012 | Washing Machines
Mar 13, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
The washer doesn't spin out the water. Clothes come out soaked?
if it washes ,,check your lid switch,,if it doesnt wash and spin check your motor coupling...onthejob
Jan 10, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
43 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
