Ovens Logo
Jim Figgins Posted on Jan 06, 2020
OVEN WON'T IGNITE - JUST WONDERING IF THE THOUGHT IS IGNITER OR IF THERE IS SOMETHING ELSE I SHOULD CHECK BEFORE
Max Lowe
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
Problem Solver:
  • Contributor 12 Answers
  • Posted on May 17, 2020
Max Lowe
Contributor
Level 1:
Welcome Back:
Problem Solver:
Answers
12
Questions
0
Helped
3535
Points
35
One of the relays on the relay control might be faulty, in that case a new board is probably required.
Or the igniter has an issue...Igniters are the number one cause of an oven not turning on. Igniters open the safety valve and heat up to ignite the gas in the burner assembly. It can be tested with a multimeter for continuity and replaced if necessary.
I got this from: https://www.electrafixbc.ca/appliances/stove.html
Check it out for more info on your oven issue. Good luck!
3 Related Answers
Ken Bledsoe
  • 306 Answers
  • Posted on Dec 03, 2008
SOURCE: THE OVEN WILL NOT HEAT
How old is the unit? Sometimes the igniter can glow but if it isn't drawing the right amount of power to open the gas valve then that is the safety that is built into the oven... So unless the power requirement is meant gas valve will not light. Even though the hot surface igniter is glowing red hot. chances are the igniter is bad. Let me know what turns up. ken
Anonymous
  • 43501 Answers
  • Posted on Nov 24, 2010
SOURCE: It doesn't ignite the oven.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Anonymous
  • 43501 Answers
  • Posted on Jun 27, 2011
SOURCE: GE JGBP33 gas oven will not light. Burners and
heatman101
Gs773lxss0 will not light
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start/
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/18---/Oven-won-t-turn-on-
Oven Won Turn on http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start
Mod# xfg374lvq stove: Both the oven and the broiler will ignite, but only stay on for a few seconds. It does not try to reignite. Is this the control module?
Most modern ovens use an electronic control board
to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced.
The oven sensor: works with the oven control board to regulate the oven temperature. If there is an oven temperature problem, this sensor might be defective. The sensor can be tested by using an ohm meter. As temperature rises, the resistance measurement also rises. The manufacturer of the oven sensor determines the correct resistance, Oven temperature problems can be caused by other things, but this is one of the common causes.
Beware on some models now most of these ovens they are electronic and they are integrated into the control itself
some different sensor ohm readings at room temp. approx 16 ohms at room temperature and at 350?F it is 29~33 ohms.
http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start Oven Won Turn on
Oven won't ignite
heatman101
Stove top burners work but when the oven is turned on it looks like the pilot light will glow but will not ignite the oven
The problem beleive it or not is that the bake igniter is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake igniter(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of igniter make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake igniter. I know it seems improbable that if the igniter comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the igniter comes on yet the oven won't heat that a weak igniter is the cause 100% of the time
Gene...OldTech2332
Turn it on at 350degrees it won' ignite and eat but will work on boiler
Oven not Working or
Oven not Heating
heatman101
Jan 24, 2011 • Ovens
Oven won't light. Broiler will ignite and
I don't know how new or what brand your oven is, but chances are you have a bad igniter the bottom burner. It is a small element attached to the burner that should glow red hot when you turn your oven on to ignite the gas. This is the most commment setup and problem. You will have to remove the bottom tray (there are usully 2 finger screws holding it in) to see it. It should look something like this:
http://www.theignitorstore.com/product/306602/range_oven_igniters
If you turn the oven on and nothing happens, turn it back off. You can disconnect the igniter, connect a multimeter set to volts AC, turn back on and check for voltage (120 AC) Don't let any bare wire ends touch the oven or you. If you have power there, its the igniter.
Just get the model number off your oven to look up the proper replacement. Replaces with 2 screws. Make sure it mounts close to the burner. It should only take a couple seconds after you hear the gas turn on to ignite. Hope this helps.
Jan 02, 2010 • Ovens
I have Fridgidaire 30'' wall oven. Tried to bake something but only the broiler will ignite. NOT the oven! AHHHH...I want to cook my meatloaf. Help?
your model says its a 24"
but the hot surface igniter for oven is bad
it should have a seperate one for broiler
check here on fix ya ( hot surface igniter)
GE Oven does not ignite, bute Broiler does.
Your problem is with the oven igniter. You have the stove MODEL# so you should have no problem finding the part you need.Shop around to get your best price. Good Luck Friend.
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
