SOURCE: Motor not working on Delta table saw: I just got a
Ok, the motor turns, but throws sparks on the brushes. This is normal to an extent for universal motors used on that type of equipment.
Try reassembling the saw, and put a blade on it, then try it. If it runs, try cutting a piece of scrap 1x, both crosscut & rip. If the motor can't hold the load, you may still have to replace it.
SOURCE: New or used motor for a Craftsman 10" table saw
You can try Sears but they can be a bit pricey. I use to send out motors for a factory I worked in to a rebuilder who would even do new windings. Check in your area for a rebuilder, As for the replacement being a Sears unit they may have a similar motor in stock. Good luck.
SOURCE: Delta Table Saw stopped running
I have a table saw that the cord from the motor plugs into the the back of the on/off switch. I yours is configured like that, unplug the motor cord from the back of the switch and plug it in to the wall and see if the motor will run. If so replace the switch.
SOURCE: I need a manual for a delta saw
Here's a free manual you can download that provides an exploded view of all the parts and a complete listing of each part in the saw.
http://www.ereplacementparts.com/images/dewalt/34-670_Type_2.pdf
Here's a link to the Delta-Porter Cable website where you can also get a free manual via download. Just select which version you have, either Type 1 or Type 2 on the bottom of the page and download that for free
http://www.dewaltservicenet.com/SearchResults.aspx?q=34-670
Hope you find this Very Helpful and best regards!
Sears no longer sells repair parts for this motor, only the whole motor as a replacement part, and it is $140.00, but you can buy replacement bearings from drillspot.com the bearing needed is an Enduro 6200 zz c3
