That means the Source or Input has been changed to the number 1 HDMI Port and there is nothing attached to it, or if there is a cable box on it, the cable box is turned off. Check that first and then press the Source button on the television remote until you find a signal. You can check the HDMI sockets at the rear of the set and see if anything is plugged in. They are numbered, normally 1 to 3.
although channel 76 is starting transmissions on Sunday 25 feb press releases and statements from channel 7 state that channel selection and programming for sets may not be effective until Wednesday 2 march
if you have the latest digital led you beaut tv , it will still not select until 76 comes on line as there is nothing to select ( there has to be a signal transmitted for the tuner to find it)
ask the question again if you are not successful after Wednesday
Do you want to know the video formats that can be played with this set? Refer its user manual. Its specification page will give you all details. http://electronicshelponline.blogspot.com/
check source setting via remote. If you have digital television then DTV most likely should be the source. If using HDMI on a Video player then HDMI1 check if video player cable is plugged into HDMI1 if you have one.
Plug all cables in the ports in the back of your television, the use the remote of the television select Source scroll up or down for required hdmi channel select buy stopping it on the channel then press ok
Tries tv unplug,replug it back like about an hour later.Than tries go into the tv menu do a resetting to factory setting in every settings on the tv.Than reconnect the Blu Ray player again should work.If not the tv and Blu Ray player softwares main firmware just not compatibles.The only solution is just don't used it on this tv,because if u tries to upgrade the tv firmware or the Blu Ray firmware and u get the wrong upgradable version in the tv or Blu Ray player.That it u in deep ****,than the tv or Blu Ray player well not functions at all or have multiple orperational problems during it playing times.
You get invalid format, or format not support becuase the video resolution setting on your PC is too high for the monitor to display, you need to lower your PC video resolution to the native resolution of the TV to get the best picture. Look at the owner manual for your TV or search the web.
this player will only support mp3 or wma file formats. avi is a video format and this model does not play video accordind to it's review site. www.mp3players.alege..net/comments/430/ i hope this helps
