Televison & Video Logo
zazzy ander Posted on Jan 06, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
11 digit code for apex LD4077m - Televison & Video
Level 3:
Top Expert:
  • Televison & ... Master 76,851 Answers
  • Posted on Jun 02, 2020
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15006357
Points
237762
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
https://elektrotricks.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
3 Related Answers
dickandannet
Richard Warren
  • 2548 Answers
  • Posted on Aug 09, 2014
SOURCE: Where can I get a replacement screen for my apex
Samsung outlet should be able to come up with that.
mrb4rbz
dingledick
  • 166 Answers
  • Posted on Sep 08, 2016
SOURCE: Need 11 digit access code for apex model LD3288t, the access code text to me does not work
mak sure u have a SIM card in
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Jun 13, 2018
SOURCE: What is 11 digit access code for apex digital tv LE3212D
How would we know that??
Why is it so difficult to get the 11-digit code to an APEX TV
You don't say what type of code? A Universal Remote Code? Remote codes are only ever 3, 4, or 5 digits. Just buy a facsimile remote.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
Or this may be it?
I need the 11 digit tuner code for an Apex TV model ...
Blurtit https://technology.blurtit.com > i-need-the-11-digit-tu...
Answer (1 of 2): It's so easy to lose track of the various codes needed for our home entertainment products. Luckily, you can download the digit tuner code ...
What for is the is the 11 digit access code for Apex TV
JustAnswer https://www.justanswer.com > TV Problems
Jan 20, 2021 - Hi what I am Looking for is the is the 11 digit access code for Apex TV LD4077 for a outside ante. Technician's Assistant: Hi.
1 answer · Top answer: Please let me know if you have any further questions on this topic and I'll be more than ... ..
Will not come on
First make sure there is power in the socket you are plugging the unit into. If that's OK and the unit has been plugged in then 1) Disconnect the TV from the power by unplugging it from the wall socket. 2) Wait 20 minutes and then plug it back in. 3) Turn it on and see what happens.
I've seen a number of LCD TVs some back to life if these three steps are taken. It allows the TV to reboot itself after all internal capacitors are discharged.
I need 9 digit antenna code for Apex LD4077M to hook up antenna?
Most likely code: 10767
Others to try: 10765, 10748, 10879, 10890, 11991, 10889
To program your Comcast remote:
  1. Turn on the TV or other device that you would like to program.
  2. Press the TV button on your remote control.
    NOTE: If you would like to program your remote control to work with a DVD Player, VCR or Audio device press the AUX button.
  3. Press and hold Setup until the red light blinks twice, then release Setup.
  4. Enter the first code for your device listed above. If you perform this procedure correctly, the red light will blink twice.
    NOTE: If you enter an invalid code, the red light will display one long blink and exit the programming mode. Repeat steps 2 to 4 with a valid code.
  5. Aim the remote control at your device and press Power once (press the Play key for devices that don't have a POWER button). If the TV turns off, make sure that the VOL+/- and Mute buttons also work. If so, you're all set!
  6. If not, repeat these steps using the next manufacturer's code (you may need to try several codes to find the one that works).
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_70466cb634a57543
Program Code for xfinity remote with red botton
0256,0255,0251. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
Cannot connect my Apex LD4077M to comcast. What re the codes for the remote? [email protected]
0092,0096,0097. Check these codes. If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy.
My remote doesn't work
Do you have any flashing indicator lights on the remote? If you don't you can verify your remote is sending IR signals by pointing a cell phone camera at the front of the remote and viewing through your cell phone screen while holding down a button on the remote. You should see the flashing IR light on your cell phone screen. If you do not see the flashing light either the batteries are no good, or the remote is not getting power due to a problem with the circuit board.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
