Hi.
The E-2 error code relates to a communication error between the computer and the resistance motor. In most cases, this is caused by the cable that plugs into the back of the computer not being properly inserted into its connection point or by a bent pin on that connection.
Please unplug the cable that plugs into the back of the computer and check that none of the pins are bent. If a pin is bent then gently push the pin back into a straight position. Once the pins have been checked re-connect the cable and firmly push it into position.
Good luck.
SOURCE: tunturi elliptical cross trainer error e-2
Most E 2 code means communication problem upper and lower boards you will need to check connector. for further info go to http://accellfitnessna.com or Email [email protected] they will help you they Tunturi Distributor of North America
SOURCE: Power ramp does not work.
Ignore everything above - most of the time this is an easy fix. Usually, it happens with a brand new console, or a machine that has reset itself.
Hold down the incline up (on the console itself) button and the start button at the same time. Then follow the instructions on screen.
It will run through an initial calibration, and once complete, the ramp will now work. Just did this with mine, and my ramp is now working perfectly.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
SOURCE: Sole 235 elliptical causes static that interferes with the tv and pvr.
the machine has has front drive system which indicates an electric motor
static can be caused by brushes arcing on the commutator bars
that would require a check by an electrician or technician
removing the rubber mat will do nothing as I suggested
the arcing is causing the static so it is severe
if the machine is under warranty , get it checked by a warranty technician or service agent
failing that the capacitor is fitted across the power and neutral points at the back of the power point
Testimonial: "Thank you, Where is the power point, an neutral points? It is not under warranty, and is 2nd hand. Kind of confused as to why this would need to be done. Thanks."
