Question about Panasonic Lands Phones
Need help with blocking on my Panasonic phone KX-TG7731. I removed all blocked numbers using *217, but a relative is getting blocked. My ISP says that there are no blocked numbers thru their service.
Anonymous
SOURCE:
Anonymous
SOURCE: I would like to remove
I have the same phone:
1. go to the number in the phone book that you want to delete
2. simply push the clear button on the phone (also the mute button)
3. then select yes
ta-da! ^.^-
Posted on Jul 20, 2008
Anonymous
SOURCE: Does Motorola SB5100 SURFboard modem block ports?
i dont see ruter for may Motorola SB5 100E
Posted on Aug 31, 2008
Anonymous
SOURCE: kx-TGA641T how does one unblock blocked number
http://ww2.justanswer.com/uploads/MCVGreg/2009-09-21_023145_KXTG9331-Remove-Blocked.pdf
Viewing/editing/erasing block call
numbers
1 {MENU} -> {#}{2}{1}{7}
2 {V}/{^}: Select the desired item.
~To exit, press {OFF}.
3 Proceed with the desired operation.
■ Erasing a number from blocked list:
{Erase} -> {Yes} -> {OFF}
you can also edit:
■ Editing a number:
{Edit} -> Edit the phone
number. -> {Save} ->{OFF}
Posted on Feb 28, 2010
cnavarro
Carl Navarro
  • 2460 Answers
SOURCE: how to block "0" for
As was pointed out to me, you could take a screwdriver and pry the 0 key off the tone pads :-)
Panasonic systems restrict calls by tables called Toll Restriction (TRS). It's a complete section in the installation and programming manual. It involves setting tables, usually in the 302-306 area, then picking a class of service for the phone that acts on the numbers dialed.
In the simplest systems, the TA series, you have 20 restrictions per class 2-5 and one 80 entry exception table. It's a little tricky to set up in that a COS-2 extension has all the restrictions in COS-2 tables, but a COS-5 extension has all the restrictions in COS-2,3,4, and 5 :-)
Your Pana installer can do this fairly quickly, but if you plan on doing it yourself, please read the TRS examples carefully.
Carl
Posted on Aug 22, 2010
cnavarro
Carl Navarro
  • 2460 Answers
SOURCE: Dear Sir, I am using KX-TEM824 PABX system and
That doesn't explain so well in a free forum. Try the features manual under TRS (toll restriction). COS (Class of Service) and Verified Toll calling. With restrictions, you set up a numbering plan that will bar mobile calls, then either verify and override, or alow only certain phones the ability to dial outside calls to those numbers. If you absolutely have to allow access to certain mobiles, you can add them to the Speed Dial tables where the call can be allowed by the fact it's in a speed call table.
It will take you 30-60 minutes to read and set up the programming.
Carl
Posted on Dec 23, 2010
How do I remove the list of blocked calls on Panasonic KX-TGA470
Note: the handset is model KX-TGA470. The phone base system model may be KX-TG7731 or another KXTG7741. Other model numbers also use this handset.
You have to remove the entries in this list individually. Press Menu followed by the following # 2 1 7 . Select a number in the Blocked call list (with the up/down arrows) and select Erase. Use the up/down arrows to highlight Yes and then press Select. Alternatively, you can use navigate the menu system and look for Initial Setting and then Call Block. Press Select to enter the sub-menus. See page 41 of the manual for the section on Editing the Call Block list. See page 37 to see the menu tree for the Initial Settings sub-menu. The manual is available here: https://panasonic.encompass.com/shop/model_research_docs/?file=/MSC/om/KXTG263SK.pdf .
I hope this helps.
Mar 23, 2017 | Panasonic Lands Phones
I need to know how to unblock a telephone number on my model #KXTGD220 telephone
Here is a link to the owners manual page for call blocking. It has a lot of abbreviations I don't understand, but hopefully they will match what you see on your menu and display.
https://www.manualslib.com/manual/888692/Panasonic-Kx-Tgd210.html?page=26#manual
Jun 01, 2016 | Clothing
How do I unblock calls on my Panasonic kx-tga470
Step 1 Press the "Menu" button followed by the "#" key on the handheld unit.
Step 2 Enter "217" on the numeric keypad to access the blocked numbers menu.
Step 3 Press the down arrow on the keypad. Scroll through the list to select the number you wish to unblock.
Step 4 Press the key under "Erase" to remove the phone number from the list.
Step 5 Select "Yes" to confirm your selection.
Mar 15, 2016 | Panasonic Lands Phones
I have a Panasonic digital cordless phone model KX-TGE210. I accidentally block a number on my phone that I need to unblock to receive calls. Can you tell me how to unblock a number?
I have similar phone.
Press Menu then enter #217 to edit blocked numbers.
Use up or down arrow to scroll through numbers.
You can erase or edit blocked numbers.
For more info, see manual at: http://www.manualslib.com/manual/754430/Panasonic-Kx-Tge210.html?page=1
Mar 08, 2016 | Panasonic Lands Phones
How to unblock numbers that have blocked?
Is this for the cordless phone? If so try this..
Feb 09, 2016 | Panasonic KX TGA641 Cordless Phone
How to unblock previous blocked numbers
Nov 12, 2015 | Panasonic KX TGA641 Cordless Phone
How to clear a memory full in the block feature on the KX-TG4031?
I have a KX-TG7644. Had to look harder for the Call Block directory. The manual really didn't help much. Press "Menu", go down to "Initial Settings", go to "Call Block". You can access the list and delete all or part to open up memory space. I had to do this after all the election calls.
Jul 09, 2011 | Panasonic KX-TG1033S Cordless Phone
How to unblock a number on model#kx-TGA931T panasonic house phone. Number was blocked by accident.
THIS IS HOW YOU DO IT!!!!! EASY VERSION
Step 1
Press the Menu button followed by the # key on the handheld unit.
Step 2Enter 217 on the numeric keypad to access the blocked numbers menu.
Step 3Press the down arrow on the keypad. Scroll through the list to select the number you wish to unblock.
Step 4Press the key under Erase to remove the phone number from the list.
Step 5Select Yes to confirm your selection.
Feb 25, 2010 | Panasonic Lands Phones
How do you remove the lock from the phone Panasonic kx-tg 5771
???Š? ?Š?????????Š ?§?²?§???© ????? ?§????????§?­ ???¬???§?² ?¨?§???§?³?????Š?? kx-tg5771bx ?§?±?¬?????? ?®?¨?±?????Š ?¹???? ?§???§?Š???Š?? amirf@mail.com
Nov 03, 2009 | Panasonic KX-TG5771 Cordless Phone
Lands Phones Logo
47 people viewed this question
Top Panasonic Lands Phones Experts
Ekse
martin hogg
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
