SOURCE: the paper in my canon
Try to check the rollers for dirt build up .... hope this can help you out a little
SOURCE: can the memory of ir 2270 copier be up graded?
there are 2 slots populate the other slot 128mb
SOURCE: canon ir 2270 having a
if it has a paper jam. it should show on the display/panel which the position jammed.
then you open up the cover of it..
Do you know what is the jam code. Probably you have the sensor in duplex entrance stuck or theduplex entrance guide stuck and not moving freely hence putting pressure on the sensor. Btoh are situated on the side door upper part. Hope this helps you solve the problem.
