If there is no response on the screen itself when you touch it, that means that the digitizer is broken and there is no way until you fix the screen. Be aware that this is not a popular tablet, so if you go to a repair shop they may quote you a fix that is more expensive then buying a new tablet. Because there is a screen pattern lock, even if you plug the device into a computer with a USB cable, you will not be able to copy anything or view anything that is on the device from a computer, because of that lock. If you could unlock the device, then yes you could copy all the data files from the device to the computer, but it is impossible unless you fix the screen. If the data is really worth it to you, then fix the screen. This is your only option.
SOURCE: How Do I Get Past a Pattern Lock MID8024
SOURCE: Hi...my goibii 7inch tablet is locked with a
look for your tablet on the internet and find the lock overide sequence keys
Hi Mercedes, you will have to perform a factory reset to take the tablet back to when new!
Power the Tablet down completely. Press and hold the Power and Volume up buttons until a recovery screen appears. You should be presented with a screen that will allow you to perform a Wipe Data Factory Reset. Perform the reset then restart the Tablet.
SOURCE: My lock screen on my surf onn. Tablet was cracked and now cant get past pattern on screen
The screen needs to be replaced and the screen is damaged.
SOMEBODY PLZ HELP CAUSE MY TABLET IS NEW AND IT WAS SAT ON AND SCREEN CRACKED AND NOW I CANT GET INTO IT
