No key combinations from manual work only standby+adv-surround. Stays on for 4 secs then shuts down. All speakers and connections are disconnected
Http://audio.manualsonline.com/manuals/mfg/pioneer/vsx819hk.html
It's in the manual. Page 12.
Resetting the Main Unit
Use this procedure to reset all the receiver's settings to the factory default. Use the front panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the BAND button, press and hold the STANDBY/ON button for about two seconds.
3 When you see RESET? appear in the display, press AUTO SURROUND/STREAM DIRECT.
OK? shows in the display.
4 Press STEREO/A.L.C to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory settings.
SOURCE: Pioneer VSX-816
With the receiver off, press ENTER + ADVANCED SURROUND keys continuously for 2 sec. and it will tell you the fault it encountered. Even if it has a short, it will still protect the speakers; however, it is still a good idea to disconnect all speakers before doing this.
SOURCE: Pioneer vsx-819H: MCACC setup won't display on tv
Its because the pioneer does not display menu options through hdmi. You have to hook up basic yellow composite to monitor out.
SOURCE: Vietnam is my mechanic. I have two Pioneer VSX
Please check your power capacitor for defective and replace with new ones.
Regards
SOURCE: how to reset pioneer vsx-819h
http://audio.manualsonline.com/manuals/mfg/pioneer/vsx819hk.html
Resetting the main unit
2 While holding down the TONE button, press and hold the STANDBY/ON button for about three seconds.
3 When you see RESET? appear in the display, press ENTER .
4 Press SYSTEM SETUP to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default
settings.
