Go to the Google Play Store. Speak "keyboard" in the search. You should see an app for Google Keyboard 2-3 down. Make sure it is enabled. Once enabled you will be able to turn off Google Speech.
Try Opening your settings.
Choose Language and input.
Tap the item google keyboard.
Ensure that the predictive text is /active. On some tablets, place a check mark by that item on others, slide the master control to the On position. Check all necessary functions that you think may cause the problem. If that doesent work, Force/restart your device. You probably done that already so if thats not it Set to factory settings. Update keyboard harddrive panel. Bad news If that doesent work could possible be a harddrive failure. I hope my advice helps you take care.
Bonjour,
Il se pourrait que ce soit un probl?me d'?cran. Renseignez-vous aupr?s d'un r?parateur.
https://www.distriphone.com/
SOURCE: how do i get google marketplace on my klu lt7033 android 4 tablet?
Grab your largest hammer and smash this POS and buy a real tablet. I am stuck with 4 of these stupid things now.
SOURCE: I want to add a password to my Irulu tablet
Instead of going to Security you should go into the lock screen options in there you can select a PIN or password
SOURCE: How do I get out of the demo mode of the Samsung S 10.5 Tablet?
Testimonial: "Thanks for your help, but I do not come any further than the welcome screen, I have been advised to run the battery down. Fingers crossed and hope for the best."
SOURCE: android tablet touchscreen keyboard broke and won't uninstall
Do a long press on the keyboard. And see if it will let you slide it off the screen if. Not go to setting language and in pot pick a different keboard. If all else. Fails reboot your phone
