Order your highly medicated cannabis strain and cannabist related accessories in our site. 100% discreet Delivery
Contact info
WHATSAPP: +16615328526
text/Call +16615328526
[email protected]
site: originalweedshop.com
Welcome to the Original Weed online shop! We strive to offer you the best and widest selection of countercultural products. From 13 different cannabis strains, vaporizers, glass bongs and smoking accessories to grow kits, extraction kits and cleaning equipment. We have everything at the best price! We only deal with authentic objects ... no imitations or imitations! Browse our product categories and keep an eye out for new items as we become America's best online store!
Since 1997, The original weed shop located in Stanford Ave, Los Angeles has been steadily earning the reputation of being UNITED STATES Premier online weed dispensary!
We were the first, and remain the best head shop in the area. We helped pave the way for this industry to be where it is today and are here to take it into the future. Our brand new online original weed shop is the next step in our evolution.
https://originalweedshop.com/product/buy-pink-lady-online/
https://originalweedshop.com/product/buy-super-lemon-haze-online/
https://originalweedshop.com/product/buy-ice-cream-cake-strain-online/
https://originalweedshop.com/product/face-mints/
https://originalweedshop.com/product/buy-og-kush-online/
https://originalwhttps://originalweedshop.com/product/buy-zkittles-strain-online-min-order-1-oz/eedshop.com/product/buy-deadhead-og-kush-online/
https://originalweedshop.com/product/buy-royal-king-kush-online/
https://originalweedshop.com/product/buy-pink-budder-wax-online-min-order1-ounce/
https://originalweedshop.com/product/honeycomb-clearmin-order-15/
https://originalweedshop.com/product/ginger-dank-nugs/
https://originalweedshop.com/product/buy-viper-kush-online/
https://originalweedshop.com/product/moby-dick/
https://originalweedshop.com/product/buy-cantaloupe-haze-online/
https://originalweedshop.com/product/buy-skywalker-oghttps://originalweedshop.com/product/candyland/-0nline/
https://originalweedshop.com/product/buy-skywalker-og-0nline/
https://originalweedshop.com/product/buy-ak-47-online/
https://originalweedshop.com/product/buy-ice-cream-cake-online/
https://originalweedshop.com/product/buy-guava-cake-online/
https://originalweedshop.com/product/buy-zombie-cookies-online/
https://originalweedshop.com/product/sour-tangie/
https://originalweedshop.com/product/buy-sweet-tooth-online/
https://originalweedshop.com/product/buy-black-widow-online/
https://originalweedshop.com/product/buy-comatose-online/
https://originalweedshop.com/product/buy-rockstar-og-online/
Why Shop at ORIGINAL WEED SHOP?
Awesome selection, fast shipping, 24/7 customer service, all available in your pajamas. Or whatever you're wearing; we don't even want to know, TBH.
There are definitely differences between shopping at a local brick and mortar smoke shop versus shopping at an online headshop like ours.
Contact info
[email protected]
SOURCE: Electronic control panel stuck on Whirlpool Duet Sport Washer
it looks like the panel switch is brooken . if you take the panel off and see if the switch.it may get stuck.
SOURCE: Whirlpool duet front load washer flashes F35 shortly after start
Sud= The unit has sensed there is too many suds in the unit it will
flush and pump out for 5 min and restart on its own..This is caused by
too much soap use..
From the book :
SUD Code=
If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
SOURCE: whirlpool duet gas dryer ggw9200l need error codes
There is a mini manual located inside of the machine whith the codes and troubleshooting guide on some they are on left and some are under the top.
SOURCE: new whirlpool dryer duet steam wont work
Sound like the unit doen't know the door is closed the door switch is not working. does the light inside the drum come on when the door is open and off when the door is closed
SOURCE: Whirlpool Duet Steam Dryer Beeps 3 Times But Does Not Start
Brand new unit - same problem. After an hour of investigating, I found the issue.
You don't actually have to SLAM the door. If you look closely, there are 3 separate pins that must latch. One is a simple push-button style which latches no problem.
The others are little prongs at the top and bottom of door. The bottom prong latches cleanly, but the top one will not latch because the door is a bit too flexible.
Close the door normally, then firmly press on the top edge of the door. You will hear the final latch grab, then you press and hold the start button. The dryer starts normally.
Yay!
