It is not yet the end for your machine. The error codes refers to a faulty hard drive. You'll need a new hard drive for replacement and that will fix the problem.
Should you have any other questions just leave a message.
The Error E40 warning means the door is not properly closed. The E40 error code indicates a loss of electrical power usually but not always due to the door not shutting properly or not locking. But, since you smelled burning it could be any electrical short that blew a fuse and shut the machine down. It could also be the motor windings with the internal overload protector shutting it down.
Thank you for contacting Fixya.com
To delay the 3 second shut down and enable the technician to access
service mode; open the front door and pull out the transport unit. Do not actuate front door microswitch.
Press the service mode button, enter " * 4 * ", scroll to error clear
and clear error code. Machine will automatically turn off power after
clear. Power up machine and test. If the power shuts down after error code has been cleared,
the cause of the error has not been corrected. Correct cause of error
code and clear error in service mode.
