SOURCE: craftsman 10-in. sliding compound miter saw
there should be a safety latch on the right ..down by the base or at the back you should have to press down on the saw to release it.hope that helps..
SOURCE: How to change blade on 10" Craftsman table saw?
you need to grab the blade with something.maybe some pliers(if you are not going to refurbish blade) and loosen the nut in the center of the blade. i think it is a left hand thread(cw to loosen) because of the rotation of the blade. if the nut is on the left when looking from the front it is probably left handed. make sure it's unplugged and wear leather gloves so you don't get cut. install in reverse...
SOURCE: How do I align the saw blade with the saw table
The Blade Arbor is held to the bottom of the table with mounting screws and stop/adjusting screws. Loosen the mounting screw and adjust the stop screws to make Blade true with miter slot.
SOURCE: My very old Craftsman 10"
Go to searspartsdirect.com and put in your model number. Look at the motor and wiring section. Look at item 16. The motor overload protector. (probably your reset button) WIth saw unplugged, unwire one sid of this switch and test with an ohm meter. You should read through the switch. If it is open then that's why the saw doesn't work. Many of this type of oveload requires quite a push to reset as you're flexing a klixon disc back to make contact. If is open and you can't reset, it's available there although a bit high priced.
Testimonial: "Thank you so much, I really appreciate this information and advice."
