Did you take it to a qualified repair shop? Do you know what DTC'S - diagnostic trouble code's are ?
DTC B1010 08: System Sensors Data Mismatch signal invalid
DTC B1296 01: Movable Roof Header Unlatched Sensor Circuit short to battery
DTC B1296 06: Movable Roof Header Unlatched Sensor Circuit short to ground or open
DTC B1296 58: Movable Roof Header Unlatched Sensor Circuit incorrect reaction after event
DTC B1296 59: Movable Roof Header Unlatched Sensor Circuit circuit/component protection time out
DTC B1307 58: Movable Roof Latch Signal Circuit incorrect reaction after event
DTC B1307 59: Movable Roof Latch Signal Circuit circuit/component protection time out
DTC B1395
S3 and S4 are part of the Rear Compartment Lid Release switch. The folding top control (FTC) module uses S3 and S4 to determine whether the claws at the rear of the deck lid are latched into the deck lid or unlatched. S3 closes and supplies a 12-volt reference to the signal circuit when the claws are unlatched. S4 closes and supplies a 12-volt reference to the signal circuit when the claws are latched.
DTC B3669 01: Deck Lip Position Sensor Circuit short to battery
DTC B3669 06: Deck Lip Position Sensor Circuit short to ground or open
DTC B3669 58: Deck Lip Position Sensor Circuit incorrect reaction after event
DTC B3669 59: Deck Lip Position Sensor Circuit circuit/component protection time out
DTC B366A 58: Deck Lid Latched Left Front Sensor Circuit incorrect reaction after event
DTC B366A 59: Deck Lid Latched Left Front Sensor Circuit circuit/component time out
Your best bet , take it to a qualified repair shop .
Either the power to the DVD unit is off for some reason or the signal connection to the entertainment unit is loose. It sounds more like a power issue, since the ent. unit senses the DVD but can't access it. Have the dealer check it out.
Check to see if you have the "Rabbit ears" plugged into the correct spot and you are on "Analog tv" if you are trying to use digital tv on "Rabbit ears" it can't send out a strong signal like the areal ontop of a house. You may need to get an adapter to broadcast a stronger signal but even better if you can connect to roof antena.
The tv is good,just some LCD tvs some models require a very strong broadcasting signal to get a picture.U getting a free DTV air broadcasting signal wright?Tries getting a roof antena or a digital design antena.Tries this tv out again,will get all the DTV free air broadcasting signal.Should not get anymore "No Signal" result.
Only if the signal in your place is too weak do you require to have an external antennae mounted on the roof .
So check your signal strength, if not try changing the direction and the Antennae spacing to give better clarity and sound.
If not the tuner can be faulty
Usually means just that.
The input source you have switched to has no signal.
Does it have built in freeview? just plugging an ariel off the roof no longer works without a digital receiver.
OK, as the answer is important in determining where the problem lies I'll wait until your attempts to determine the history of this fault have been completed.
