SOURCE: Vicks caporiser is spitting water instead of steam
Clean the unti - and do not add salt. I live in a major hard water city...and was amazed at how much dirt the tank collected. I tried adding salt to to stop the spitting, which did make a lot more steam, but did NOT stop teh water spit. I also noticed, with salt added, water in tank would only last 4-6 hours, not the 18-24 hours it should. I just figured it out, and now mine works great again, and does not spit. I cleaned the water tank throughly, several rinses, then wiped out entire inside. If you want it to work like new, you have to keep your tank as clean as new. I am going to start filtering my water that I put in with a double pantyhose I made simply so there no more dirt ~ a clean tank will fix the problem, it did mine :)
SOURCE: cleaning
For Model V745A Vicks Warm Mist Humidifier:
Weekly Maintenance (Removing Scale)
SOURCE: no manual how do i clean a kaz vicks humidifer
http://www.ehow.com/how_7442829_clean-vicks-humidifier-model-v4450.html
Cut and paste the below URL into your address bar. Select you model and download the manual.
http://www.coldandflushop.com/cold-flu/customer-support/product-manuals/
