Washing Machines Logo
Jillian Colburn Posted on Jan 03, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Kenmore washing machine that we recently took apart to clean thoroughly! Now it only fills with cold water unless we switch the wires to the inlet valve, than it only fills with hot, no matter what setting it is on. The water inlet valve has continuity. Thoughts?
brian williams
Level 3:
Genius:
  • Master 1,980 Answers
  • Posted on Jan 03, 2020
brian williams
Master
Level 3:
Genius:
Answers
1980
Questions
9
Helped
741118
Points
5402
Check wires going to temperature selector
  • Jillian Colburn
    Jillian Colburn Jan 03, 2020
    Replaced that tonight. Nothing changed.
5 Related Answers
douglas smith
  • 1462 Answers
  • Posted on Jun 22, 2007
SOURCE: Washing Machine fills slowly how to change inlet valve
switch off power remove top switch off water and remove hose. remove inside pipe from valve - usually held by just a spring clip remove electrical terminals valve is just held with a couple of screws usually - remove these and valve will come away. put back in same order
Anastasio Benjou
  • 99 Answers
  • Posted on Jan 27, 2008
SOURCE: roper washing machine mod# RAS8245EQ1
The problem is one of two parts. One is your water temperature switch or your hot water solinoid. To get to the back you must remove the hex screws on the back and then the panel is removeable.
rpbuice
Ron Buice
  • 161 Answers
  • Posted on Jan 08, 2009
SOURCE: Kenmore 80 series model #110.26882503 fills slowly
Yes, the only other thing I would do and you may have done this is to put the hose directly over in the washer tub and turn the water on to check the flow. If that's good then replace the water valve.
Anonymous
  • 52 Answers
  • Posted on Feb 24, 2009
SOURCE: Hot water not working
You say the cold water hose works on the hot water side? Or did you mean you've already eliminated the possible problem of new hoses?
If that is the case, it's definately water inlet valve. Sounds like you have a blockage in the screen (check that for me). If there's no lint stuck in the hot water screen, then you need to replace the inlet valve. It's possible the solenoid of the inlet valve on the hot side is stuck shut only allowing the cold to fill. Before you buy a new valve, take the old one out and play around with it. The plunger like solenoids will come off and you can check for debirs in there. If there's debris, clean it out and try the cycle again. If there's not debris, the part needs to be replaced.
Here's the part:
http://www.appliancepartsworldwide.com/Store_Part.aspx?Id=299098
Anonymous
  • 15935 Answers
  • Posted on Sep 16, 2010
SOURCE: Hoover Premier 710: which inlet valve to buy?
It appears your single inlet water valve has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
1helpful
What would cause a GE Harmony washer to fill too slowly? The water in cold water wash cycle literally just dribbles into the tub.
The filler hose has a wire mesh filter in it to keep the inlet water from passing particles that would keep the solenoid valve from closing completely. Shut off the water and take the hose off from both the faucet and the washer. clean the screen and check the one in the washer too.
Why is my Kenmore elite three speed top loader washing maching model number 110.23022101 only washing on HOT water? The cold will not work. We recently had workers remodeling that room and the washing...
Make sure the cold water supply is on and not blocked.
If the machine fills but does not wash try to find a thermal switch that is supposed to come on when the cold water has heated up.
My kenmore 27 wide laundry center will not fill on rinse cycle! the water runs, but does not fill??????
If water is entering the tub on rinse and running out, the drain line is too low or siphoning the water out.
If it is not entering the machine the cold water inlet valve has trash in the screen and must be cleaned.
A test is choose COLD FILL and turn the machine on for regular wash. If no water enters,turn off the water supply and remove the hoses from the machine. Look inside the cold fill connection and clean the screen.
2answers
Kenmore washing machine 110.20922990 cold water filling slowly
Good day,
As far as cleaning the screen, you can pry it out and toss it. It may serve you for a while. The option, is to remove the valve completly, and clean it under running water with something like a stiff toothbrush.
Note: If the hot side is filling decently, then the cold water side of the valve is swelling internally, and the valve needs replaced.
In this area, the parts houses sell a GE universal water valve that is very good, and might be cheaper than the original. It's all I use.
Part # WH13X81.
Dec 17, 2009 • Dryers
Cold water is slow when filling for rinse cycle
Turn off the cold water.
Remove the cold water hose from the machine.
Look inside the cold water inlet on the machine and clean the debris from the screen.
Problem solved.
Cold water fill cycles very slowly on and off during fill
Replace the cold inlet valve, it is obviousl faulty, unless of course it has a filter, if so, then remove and clean.
Plz rate my solution
Thanks.
Kenmore front loader ,, fab softner will not empty
your cold water may be the issue, turn off your water and check the screens to the cold water side. make sure the machine gets cold water.
Slow rinse cycle fill
take the hose off the cold water valve and check the screen on the water valve ,make sure the cold water is on all the way and the hoses are on the right valves get a water bucket hold the cold water line in it open the cold water valve to check the pressure
Alexander
vince
