If you wish to get some details; check the site linked here. Pull up older posts.
https://elektrotricks.blogspot.com/
https://homenol.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Screen-shots to defective LCD panels are given. You can see and compare to that to your TVs', and can make sure about the fault to an extent.
Type in the brand name of your device in the search box, and hit enter to get gathered related posts. See the website either in Webview with a mobile, or by a desktop computer. Mobile view has no search box.
SOURCE: Danby Air Conditioner
I have the same problem with my Danby AC unit...every 5-20 seconds it makes a god awful clicking noise...Make me wanna cry
SOURCE: shimmer and bands
i experienced a tainted vertical black lines on the boths sides of my lcd screen. There was no scratch or whatsoever that could be the reason why thsi balck colored vertical lines to spread. Hope you can help me solve this problem. Thank you..
SOURCE: broken horizontal stripes except for 6" band
there are two convergnece boards in this tv. one is called the convergence (DCU) the other is called the convergence amp board. this amp board has the (STK`S) on it and ids your problem. in most cases we repair this board.
good luck :)
let me know if you need more info?
SOURCE: ps 27123 have sound, tuning etc only small horizontal color band
Hello bdedrick708,
If what you are trying to say is that you have a 1/4 inch horizontal line across your screen, this means that something in your vertical deflection circuit has failed. This could be the vertical oscillator, the vertical output processor, the vertical coupling capacitor, or the vertical section of the yoke transformer.
If what you are talking about is a vertical line from top to bottom then you are possibly talking about a failed horizontal section of the yoke transformer.
Why so little about the horizontal section of the yoke? That is because if the horizontal section fails completely then you would lose high voltage and no line would be present because you would not have raster (screen light).
In any even check the yoke transformer first. Then work back from there.
I hope this helps,
Thank you,
Shuttle83
llc.com/">http://www.electron-age-technologies-llc.com
SOURCE: a three loud consecutive popping sounds at various
You probably have a bad compressor. It's internal parts are held up with 4 springs and one of them has probably broken and causes the compressor piston to hit the side of the comp. housing. This will happen when the ref. shuts off. To be sure, if you turn the ref off at the controls then you should hear the noise in the back. If it is less than 5 years old you can get it replaced under warranty. if more than 5 years old it will just be noisy. it will most likely last several more years like it is. Let me know if I'm right.
