Drills Logo
Nicole Rounce Posted on Jan 02, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Help! My screwdriver bit is stuck in the Dewalt 682 gyroscopic screwdriver. How do I get it out??
Don A
Level 3:
  • Dewalt Master 4,495 Answers
  • Posted on Jul 03, 2020
Don A
Dewalt Master
Level 3:
Answers
4495
Questions
5
Helped
1336347
Points
25824
For some reason, I can't find your screwdriver on the Dewalt site. They suggest calling them if you can't find an item. That info is below. That said, here is a YouTube that may be of interest. Be careful and don't burn yourself.
https://www.youtube.com/watch?v=-z6izpCslFM
https://www.youtube.com/watch?v=q7zra2v_Bb4
https://www.wikihow.com/Remove-a-Drill-Bit
https://www.dewalt.com/support/
call Dewalt: US: 1-800-4-DEWALT ' Mon - Fri 8am-5pm EST
3 Related Answers
Anonymous
  • 79 Answers
  • Posted on Jun 18, 2009
SOURCE: how do you load screws in Dewalt DW272WT VSR
You definitely need a hex-bottomed screwdriver bit. Please rate me
Anonymous
  • 12 Answers
  • Posted on Jul 14, 2009
SOURCE: the bit is stuck and i can't change it
try clamping the bit in a vice and rotate sharply left and right while pulling on it, cam
Anonymous
  • 4088 Answers
  • Posted on Jan 27, 2011
SOURCE: Dewalt DW251 VSR Drywall screwdriver.
The bit should just pull out, but will be difficult to start because of the latching mechanism (magnet). Good luck!
How do I get a stuck bit out of my DeWalt dc 895?
https://www.youtube.com/watch?v=pNDgV_6k12E
Reverse and Forward Mode: Try putting the drill in reverse mode and hit the trigger, then forward mode. If that doesn't work, tap the tip on the driveway but don't slam it. It should release .
Use a Wrench: First, make sure that the chuck is in the locked position. Next, use an allen wrench to loosen the set screw on the side of the chuck. Finally, unscrew the drill bit from the chuck .
Remove Chuck Collar: Use a wrench or pliers to loosen the chuck collar and remove it from the chuck. Then, use a screwdriver or other tool to remove the chuck jaws and any other components that may be blocking access to the stuck drill bit. Once these components are removed, you should be able to access the drill bit and remove it from the chuck .
DeWalt 20 V impact. Driver ejects occasionally. Locks in correctly to start then after limited use, bit holder falls out.
These are known for the spring in the nose (#12) to fail.
Using an o-ring pick or small screwdriver remove the hog ring on the end of the bit holder (#17).
Slide the washer, spring, and sleeve off (Be careful not to lose the small lock ball)
The spring that pushes the lock ball forward (#12) is usually the culprit.
Reassemble in reverse order DeWALT DCF886D2 20V Impact Driver Parts
1helpful
How to remove philips bit stuck in dw054 anvil?
Can you drill a hole in the bit? If so, put a metal screw in the hole and pull that out??
GL,
Td
How to remove the bit from DeWalt DW272DT drywall screwdriver
If the bit is stuck in the spindle there is no easy fix I know. you just have to try to get hold of it and pull, try giving it a little twist as you do it.
Jan 23, 2013 • Drills
2answers
My drill bit has stuck in the chuck of my dewalt sds chuck ,have tried wd40 but still stuck
I had the same problem. I put the drill onto Hammer/Chisel action and it helped release the bit.
I have a DCD940KX 18v Dewalt drill driver with the one click drill chuck. It does not keep drill bits or screwdriver bits from spinning. They spin with the slightest bit of pressure on them. My questions...
this is not a common problem with dewalt. I have been using them in my construction business for years and only heard of this once or twice. I would go to their web site and get the number for their customer service. They stand behind their products and im sure they will help in every way they can to repair the drill
2helpful
How to change the drill bit for a Dewalt DW995
That tool comes standard with a keyless chuck so all you should have to do is grip the collar and turn it to loosen bit. If it is stuck you might try a rag of some sort on the collar and use the motor to loosen it up. Let me know if you need more help.
How do you load screws in Dewalt DW272WT VSR
2helpful
6answers
How to Remove Bit from Dewalt Quick Connect Adapter DW0521
Hold the chuck by its sleeve, put the drill in reverse (make sure it's set at high torque if you used it in a drill/driver) and go full speed. That should release the bit.
3answers
Dewalt dw997 drill clutch stuck
your drill required trans assy & clutch assy for $132.00 plus tax canadian max repair/
thanx
Top Dewalt Drills Experts
Sean Wright
Sean Wright
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
