Question about Humidifiers
I need to replace the water tank for holmes humidifier 1865
    Top Expert:
  • 30,872 Answers
Anonymous
SOURCE:
Anonymous
  • 123 Answers
SOURCE: Humidifier does not reset
According to Holmes, one of the causes of the Reset light staying on is scale buildup on the heating element.
Remove Scale: Allow to cool before maintenance.
1. Repeat steps 1-5 in the Daily Maintenance section.
2. Clean the base by partially filling the base with one
8-oz cup of undiluted white vinegar. Let solution stand
20 minutes, cleaning all interior surfaces with a soft
brush. Dampen a cloth with undiluted white vinegar
and wipe out entire base to remove scale.
3. Rinse with clean warm water to remove scale and the
white vinegar solution before beginning to disinfect
the tank.
4. Wipe the heating element clean with a soft cloth after
it has had chance to cool.
If the scale has really built up it might take longer than 20 mins for the vinegar to get rid of it and you might need to refresh with new vinegar.
Your Manual can be found at this link:
http://www.holmesproducts.com/Manuals/Holmes/HM5250-UC_English.pdf
Good Luck.
Posted on Apr 18, 2008
Anonymous
SOURCE: reset light on holmes product hls5000 humidifier
turn knob to reset....leave 15 minutes and then turn on
Posted on Feb 03, 2009
Anonymous
  • 114 Answers
SOURCE: wondering if damage to Holmes HM500 humidifier is fixable...?
unfortunately running the unit for too long will permanently ruin the unit. there isn't really a way to fix it. i do deeply apologize for that. so unfortunately you might have to replace the unit.
Posted on Aug 29, 2009
Anonymous
  • 7 Answers
SOURCE: Need Manual for Holmes Humidifier HM4600
because no one else posted the site, heres the pdf
http://www.appliancefactoryparts.com/content/pdfs/116674.pdf
Posted on May 17, 2010
jboyd12
jboyd12
SOURCE: holmes HM4600HD humidifier tank
Mine dried out too. I could not find where to get the rubber valve seal for the tanks. Holmes does not list the part and when I called the rep told me they didid not stock the part. I solved my problem by purchasing thin rubber washers from Lowe's. They are 3/16 X 1 1/4 X 1/16 thick. The 3/16 hole in the center "snaps" on over the end of the plastic plunger just like the original. I had to trim the outside diameter with scissors to about 1" or using the old ones as a guide. Cost me $0.67
Posted on Jan 10, 2013
Why does my humidifier holmes 1700 blows air but no water or mist?
If the water has been sitting in the reservoir for days without use, it may develop a film on the ultrasonic element which inhibits the creation of the mist to come out the top of your humidifier. I would lift off the tank and empty the reservoir. Then VERY GENTLY with a piece of paper towel, wipe the ultrasonic element (looks like a disk the size of a quarter at the bottom of the reservoir) to clean off any film. Then replace the tank and let the reservoir fill up the tank and try it again.
Good luck
thebqe
May 04, 2014 | Holmes Products Humidifiers
Sunbeam humidifier 3502
Tanks are no longer available. Search for used units on your local craigslist.com. This model was previously made by Holmes and tanks were the same on HM3500, HM3501. Search "Holmes humidifier" then search "sunbeam humidifier" on your local craigslist.org
most bigger towns will have one or two show up. Keep an eye out. People who move to a house (or install) a whole house humidifier sell their old units. We have two of the exact model and I bought a new in box 3501 from a Craigslist posting in September 2013!
Mar 13, 2014 | Sunbeam Humidifiers
Refill cap center plunger is broken
I dont see any other way to fix other than purchase another cap...
I ordered 2 replacement caps from here they were the cheapest tat I found http://www.jardenstore.com/productdetails.aspx?BrandId=494&pid=1783 but they seem to be out of stock at the moment These http://www.appliancefactoryparts.com/humidifiers/holmes/holmes-water-tanks.html are 3 dollars more here hope this helps
Jan 29, 2014 | Holmes Products Warm Mist HM5700...
How do I clean my humidifier Holmes hm 500? I don't have the manual anymore. Thank you! Jaimee Murphy
If you are trying to descale it of all the mineral build up. The easiest way is to mix a 50/50 1 gallon solution of Distilled White Vinegar and Bottled Distilled Water and pour it in the empty tank. Allow it to sit for a couple of hours (Longer if it's really scaled) . Then turn it ON and run it, until the tank is half empty. Then empty the remaining solution and fill the tank with Bottled Distilled Water and run until it's empty. In the future, it's better to use Bottled Distilled Water, rather than tap water.
Hope this helped you and thanks for choosing FixYa.
Aug 26, 2011 | Holmes Products HM500-UC 1 Gallon...
I HAVE A HM 5700 HUMIDFIER AND NEED A NEW CAP FOR THE TANK CAN YOU HELP ?
Jan 06, 2011 | Holmes Products Warm Mist HM5700...
Can I get a replacement tank for Sunbeam humidifier model #SWM5251
Hi, unfortunately there's nowhere to purchase a replacement tank online. You can buy a new humidifier from Walmart for $25 when they replenish their stock:
http://www.walmart.com/ip/Sunbeam-Warm-Mist-Humidifier/12356384
Or you can get one for $29.29 branded as Holmes instead of Sunbeam from DrillSpot.com:
http://www.drillspot.com/products/1347166/jarden_consumer-heater_hum_swm5251-um_small_room_warm_humidifier
eBay also currently lists 3 of these humidifiers, being sold for $34.99 each (also branded as Holmes):
http://shop.ebay.com/?_from=R40&_trksid=m570&_nkw=swm5251&_sacat=See-All-Categories
Jan 13, 2010 | Sunbeam Health at Home Warm Mist...
My Holmes HM3500 Humidifier is plugged in and full of water. Just replaced filter. Filter has soaked water all the way up to the top of filter. Both lights are lit, but fan is not turning on. I have tried...
The tank may be full. Your dehumidifier has a safety device that turns off the dehumidifier when the water tank is full. Usually the tank itself either presses against a switch or there's a device connected to the tank that triggers a switch when the tank is in place and full.
If you've emptied the tank and the unit doesn't run, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
Post comments  for more help or information .........
Good Luck!!
Thanks
Dec 22, 2009 | Holmes Products Cool Mist HM3500...
Need to find a new water tank
Mine also cracked along the seam several years ago. I sealed the crack using two-part waterproof plastic epoxy (found at any hardware store.) Not really pretty to look at, but it hasn't leaked since!
Dec 01, 2008 | Holmes Products Cool Mist HM3500...
Holmes HM4600HD humidifier tank
Nov 09, 2008 | Holmes Products HM4600-U 11 Gallon...
Will not reset
Per the operators manual you have to reset it. 1. Unplug the unit
2. Remove and refill the water tank, being sure to follow the Daily
Maintenance Instructions. Replace the tank onto the base.
3. Wait 5 minutes for the Automatic Shut-Off to reset.
4. After the 5 minutes, plug in the unit and turn the unit on to HIGH
(HI). The RESET light should now be off (if not repeat steps 1 through
3). In about 2-3 minutes, the humidifier will begin to produce
moisture.
Jan 03, 2008 | Holmes Products (048894556579) 4 Gallon...
Humidifiers Logo
Top Humidifiers Experts
Paul Carew
Dennis
Marvin
Marvin
Are you a Humidifier Expert? Answer questions, earn points and help others
