SOURCE: PRODUCT KEY FOR MS-OFFICE 2003
If I understand your problem...
You do not have the product key?
Or, are you having problems installing the product key?
If you have a bootleg copy of the software there is nothing that can be done for you.
You must not have the program installed on other computers.
You must purchase an original Microsoft CD.
-- If you do have a legal version...
First check and see if your "Caps Lock" is on?
Be absolutely sure that you are entering the registration code EXACTLY as printed, Use CAPITAL LETTERS as printed, and lower case letters as required.
If it still won't work....
Call Microsoft and explain the situation, have a magnifying glass handy to read the tiny engraved lettering in the center of the CD disk.
If you have some kind of sales receipt, or other "Proof of Purchase" have it handy too.
They can create a new product key for you.
This method will only work if you have a legal copy of the program.
SOURCE: product cd key ms office std edition 2003
If you have a bootleg copy of the software, there is nothing that can be done for you.
No temporary product key is required for the trial period, unless that has changed in Office 2007.
Did you purchase a new computer with office 2007 installed already?
SOURCE: Error 1317 when trying to open Word docs in MS Office Pro 2007
Many instances of error 1317 relate to incorrect or insufficient permissions. If you are operating as an administrator on your system, regardless of operating system, this obviously should not be an issue. (FYI - a selected reference would be at http://support.microsoft.com/kb/306986).
In other cases, this particular error message indicates that the underlying file is corrupted. Further, as there is often a conflict between Outlook 2007 and Word 2007, particularly if Word is acting as the default email editor, would suggest making sure that Outlook 2007 is closed.
If you feel certain neither of these issues is the root cause, I would suggest defragmenting the hard drive, and then running a chkdisk with repair. If this is unresolved and you need further assistance, please check your Event Viewer for particular messages at the time you received the error, and post those back, along with the operating system you are running and your user permission level.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
SOURCE: 25 digit key product of ms office professional 2007
HI,
The product key,would be located on the cd cover. If you are not using the original cd . Then you would have to call microsoft to get one.
Thanks
proton
