Lands Phones Logo
j
joseph Faraldo Posted on Jan 01, 2020
Just got 20,000 mike service and now there is a symbol displayed as a A with a line around it over the top of the A with an arrow head pointing down on the right. What is that mean?
Nick Charalampakos
Level 1:
  • Contributor 36 Answers
  • Posted on May 27, 2020
Nick Charalampakos
Contributor
Level 1:
Answers
36
Questions
0
Helped
8199
Points
61
Try to go to settings and change the language or the type of fonts....
5 Related Answers
Anonymous
  • 105 Answers
  • Posted on Jul 25, 2009
SOURCE: i have ae blue arrow with a line under at the top
please clear your model
Anonymous
  • 1884 Answers
  • Posted on Aug 22, 2009
SOURCE: Unknown symbol on my Nokia E51
That symbol means that there are msgs waiting to be sent in the out box. You cant get rid of it as there are msgs in the out box. Either send them or remove them.
Anonymous
  • 34 Answers
  • Posted on Oct 30, 2009
SOURCE: dashboard symbol - triangle with an exclamation
Hope this helps!
Anonymous
  • 34 Answers
  • Posted on Oct 31, 2009
SOURCE: Unknown symbol top left hand side of screen
It Denotes, "Call Forwarding Feature is Activated"...
Testimonial: "Great stuff! Thank you so much"
Anonymous
  • Posted on Nov 29, 2010
SOURCE: flashing red symbol like a bowl crossed out
it means you have no back up battery installed to save time/date info. I know on the GL2 if you open the LCD screen there is another small plastic tab you can open and insert a relatively small battery. Do it and the icon will disappear. Otherwise its no big deal. If you dont need time/date stamps on your tapes then there is no need to install the battery unless you are just annoyed.
Bosch SGV46M13GB dishwasher - tablet dispenser not opening error code showing S shape with arrow heads top arrow pointing east bottom arrow pointing west
The symbol you're describing is saying the salt tank is empty. Normally on this model if the dispenser isn't opening it's because it's not heating, the dispenser is triggered when it reaches a set temperature
How can i unlock my firefly mobile s070 i forgot my pattern password
Instructions
    • 1 Press and hold down the lock button on the Firefly phone until the screen says "Enter Pin."
    • 2 Press the "Enter" button to begin entering the PIN number.
    • 3 Press the right arrow button once. You will see the number one.
    • 4 Press "OK." You will see an asterisk on the top line.
    • 5 Press the right arrow button twice until you see the number 2.
    • 6 Press "OK." You'll see a second asterisk symbol on the top line.
    • 7 Press the right arrow button three times until you see the number three.
    • 8 Press "OK." You'll see a third asterisk symbol on the top line.
    • 9 Press the right arrow button four times until you see the number four.
    • 10 Press "OK." You'll see a fourth asterisk symbol on the top line. The phone will unlock.
    • Read more: http://www.ehow.com/how_6361971_unlock-firefly-cell-phone.html#ixzz309pjkqds
2helpful
Cannot get the pulse tone off the line and that prevents from voicemail access and call forwarding HELP!
In guessing that since your lines have defaulted to pulse dialing that you have an older Nortel system such as an 8x24 or a 6x16 system. That being said you'll need to program touch tone dialing on each line.
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
the display says A. Configuration
4 top line/feature keys are now used for programming
Press the show key (top right arrow)
the display will say1. trunk/line data
Press the show key (top right arrow) .
the display will say line 001.
the display trunk data
press the show key (top right arrow) Press the next key 7 times(bottom right arrow) .
The display should say Dial mode: pulse.
Press the Change soft key (below the display).
the display should now say tone. press the heading key (top left arrow) to get back to "trunk/line data" repeat the steps for the remainder of your active lines
press Rls when finished
1helpful
I would like to change the display names that are attached to each line. How do i do this?
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
Press the next key (bottom right arrow) .
The display should say Lines.
The display should ask for a line number
Press the list soft key
The display should say Line001 and the line name. if this is the line name you want to change... Press the show key (top right arrow)
The display should say Name
Enter in the new name for the line
Press the next key (bottom right arrow) . If you want to program additional line names press the heading key(top left arrow) till you see "Line 001; new name" and press the next key (bottom right arrow) repeat the procedure for the additional lines
press the Rls key when finished
3helpful
How to set up restrictions through line restriction filters
It's best if you use the "reply to post" window below the solution box so you can continue the same thread with the same person.
To set up the restriction filters we'll need to get into programming.
At the terminals&sets prompt, press the next key (bottom right arrow).
The display should now LINES.
The display should now ask for a line number.
Enter line number you want to change the line filter on. ex. 002 = line 2
The display should say Trunk/Line data
Press the next key 2 times (bottom right arrow) .
The display should say Restrictions.
The display should say Restriction Filters
Enter in the restriction filter 25
The display should say No Restrictions and the ADD soft key should appear on the lower right soft key
Press the add soft key and in the restrictions you want on the line.ex. 011any will bolck int'l dialing but not long distance. 0any and 1any will block long distance, operator assisted calls, and int'l dialing
You can also add overrides by pressing the show key (top right arrow) then the next key (bottom right arrow) .The display should say no over rides and the add soft key should appear on the right soft key.
When finished with the filter press the heading key(top left arrow)
The display should say Line restrictions
The display should say Normal:none
Press the change key and enter 25.
Press the heading key (top left arrow) til the display says Lines.
Press the back key (bottom left arrow)
The display should say Terminals&Sets
Enter in the extension number of the person you want to allow free use of the line.
Press the next key 4 times(bottom right key)
Press the next key 2 times(bottom right arrow)
The display should say Line/Set restrictions
The display should ask for a line number.
Enter in the number of the line that was restricted.
The display should say Normal: none
Change the filter to 00 (no restrictions)
That bypasses this extension from line filter 25
Press the release key when finished
1helpful
How do you program so that when the phone rings you are able to pick up the call without hitting a button. Also when you make an outgoing call and you pick up the phone you get an active line instead of...
Sets that are programmed to ring should automatically have ringing line preference.
The 4 top line/feature keys are now used for programming2.gif.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you wish to program ringing on.
The display should sat LINE ACCESS
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear only
press the Chng key till it says appear & ring
press next key (lower right arrow)The display should say line 002: appear only
repeat procedure for remailing active lines
press the heading key (top left arrow) til the screen says terminals&sets again
Prime line assignment is also programmed at the terminals&sets prompt.
press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change the prime line on.
The display should say Line Access
The display should say Line Assignment
The display should say Line Pool Access.
Press the next key (top right arrow)
The display should say Prime Line
Press the Chng soft key till you get to the desired line or pool to pick up on
When I pick up the handset on my M7208, it goes to a dead line. How do I fix this default so it goes to a line with a dial tone
The dead line needs to be taken out of the line pool soyou can grab the right line.First you need to know the line number that you need to take out of the pool.
thats done by entering feature *0 and pressing the line button for the dead line. the screen should say
L025: line 005 (the L025 is the important part).
Write it down for later.
Next you need to get into system programming.
Programming2.gif is done on M7310, M7324 and T7316 type sets.
Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming2.gif.
At the terminals&sets prompt, press the next key(bottom right arrow).
the display should say LINES
the display should ask for a line number (001-004, 025-028 *thats lines 5-8) enter line that you want to take out of the pool group and press show (top right arrow)
the display should say trunk/line use
display should say line type:pool A
press the change key until it says public
press the heading button(top left arrow) til it says lines again
repeat procedure for next line/lines
press the release key when finished
it grabs the right line.
Change extension to another line pool
Programming2.gif is done on 7310, 7324 and 7316 type sets.Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change the pool on.
Press the next key till you get to the desired pool(bottom right arrow) .
Press the Chng soft key from N to Y
Press the heading key till the display says Line Pool Access(top left arrow).
Press the Chng soft key till you get to the desired pool
Had 8 lines, now have 6, how do i change the line pool a
Top Symbol Lands Phones Experts
k24674
Are you a Symbol Lands Phone Expert? Answer questions, earn points and help others
