SOURCE: JVC GR-DVL120 Playback
hi
you should have the heads cleaning,
try to put a cleaning tape and run it for playback then try recording again
thx.
SOURCE: GR-D72 Mini DV Digital Camcorder makes clicking sound when tape running
the clicking is from the capstain turning the tape -- and perhaps the metal cage holding the tape.. if it is bent then the movement of the capstain may be pushing it in an eccentric fashion.
send it in for repair.
SOURCE: JVC Digital Video Camera GR-DVL107E
Assuming you don't see any video through the viewfinder, it could be that the CCD has died on that camcorder. It happens, though not frequently.
If the video though the viewfinder is clear, there might be some sensor on the lens ring to indicate a lens cap, or an automatic lens cap not properly disengaging when put in record mode.
SOURCE: record directly from jvc model GR-- D370U Digital Video Camera to my pc
Sorry, but it's not possible to record directly to a PC. Windows movie maker will only record from a tape. Please use a quality cable like Belkin, I have had issues with the cheaper firewire cords.
Good luck
To start voice recording, follow these steps:
1. Press the Menu button to return to Main Menu.
2. Select Voice
3. Press Play/Pause to start recording.
4. To pause recording, press Play/Pause again
5. To stop recording, press Select. A pop-up window will appear on the screen. Select Yes to
save recording. The recording will be saved in the RECORD/VOICE folder.
6. Press 'button to return to the Voice Menu.
2. Select Voice
6. Press '<< button to return to the Voice Menu.
Please leace feedback
Cheers
Andy
