Home Logo
Charles Fueglein Posted on Jan 01, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Getting my gold chain out of the bathtub drain
brian williams
Level 3:
Genius:
  • Master 1,980 Answers
  • Posted on Jan 01, 2020
brian williams
Master
Level 3:
Genius:
Answers
1980
Questions
9
Helped
741778
Points
5402
Go under house and remove drain
Drop in bathtub
people like to enjoy long, hot soak in a bathtub after a long day after work, having a proper bathtub is a must. When it comes to choosing what type of bathtub you would like, there are multiple things you need to consider.
If you have a smaller sized bathroom,
A Drop - in tub will most likely be more beneficial for space saving.
  • Drop - in bathtubs are usually lower priced .
  • You can easily have a shower head without extra plumbing hassles.
  • A drop - in tub allows you more space in your bathroom.
  • Designed with lower sides making getting in and out easier.
  • Can be fully enclosed with minimal construction.
  • Easier installation if you want a whirlpool tub.
  • Typically easier for bathing small children.
The choice of having a bathtub reflects your consciousness towards your bathroom and precise health.
And when it comes to Drop in bathtubs,
"The American Standard Evolution Bathtub"
is entirely different, universal and better fits for your bathroom.Having 21.5 inches in depth, this bathtub allows you to enjoy at least 3 inches deeper soaking bath in this bathtub. The drainage system is quick and even. American Standard Evolution Bathtub has reversible drain outlet which cleans water fast.
Read the full review to get a holistic overview including features ,specification,pros and cons.
hydro-systems-customized-bathtubs-hydrosystems-with-drop-in-bathtub-relaxation-drop-in-bathtub-nvu2yxrtj1tcjm5kl0oggpyr-5-0.jpg
May 11, 2016 • Home
Hair in a Jacuzzi Drain
take the drain plug out and remove the hair. Once you remove the hair from the drain your water will drain from the shower.
US Parts Center
Where can I BUYold eljer bathtub drain plug
Try Home Depot or your local hardware store. Or eBay.
Feb 17, 2014 • Plumbing
Americast Princeton Bathtub clogged
It'll take a very small, flexible snake to get around two abrupt 90-degree corners.
How to replace bathtub drain stop
get a new plug making sure of correct size. if with a chain, remove the old and install new.
Oct 12, 2013 • Home
The line from the flush control is a chain link and it is always getting caught up in itself allowing the water to flow after flush till i anravel it. is there a replacement peice that i can purchse that...
adjust the chain so that the flapper is not lifted so high. adjust it so that the flapper lifts high enough that the water pressure going by the flapper keeps it open long enough for the tank to empty. when you get it to do this then cut the excess chain off if it is excessive. please feel free to give me a positive rating. thanks!
Feb 15, 2011 • Home
My bathtub drain leaks. Is there a product to
No, not without sealing, I mean clogging, the drain. Do you know exactly where the leak is coming from? I would suspect that the water is getting around the drain, instead of down the drain. The visible part of the drain should unscrew from the part that is underneath. That bottom part is likely permanently sealed to your drain plumbing.
You may be able to easily fix your leak by:
#1 Unscrewing the visible drain top.
#2 Replacing the washer under that top. This will seal your tub to your drain. All water will then be forced to flow down the drain properly.
#3 Screw the top of your drain back into place WITHOUT folding or wrinkling the new washer.
Good luck
2answers
Chain Advice
not sure i know rk used to make a gold chain that was very good, stay away from ek
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
