SOURCE: Nexgrill patio heater won't stay lit
I called Nexgrill technical support at 1-800-913-8999. They are sending me a new thermo couple to keep the valve open when ignited - so the patio heater will stay on. I needed to give them the serial number (inside the propane tank door) and fax them a copy of the receipt.
Hope this helps.
SOURCE: Zoom lever sticks
Hi, the only reason the zoom lever sticks is dirt. Either dust or some sort of liquid may have spilled on the camera. If you wipe it off, it does not help as the liquid gets into the zoom lever mechanism.It will have to strippd and cleaned.
SOURCE: KichenAid K5SS Speed lever does not stay in
Hi Burt. Go to mendingshed.com, look up kitchenaid mixer parts. Near the top of the page, locate the free kitchenaid service manual. Download this valuable manual, it will help you to diagnose and repair your mixer. Mending Shed also sells KA parts. If you order parts directly from kitchenaid be prepared to wait for at least a month for the parts to arrive.
If this solution has assisted you, please rate it. Good luck! ricardok45
SOURCE: The blade lever on my sawzall is stuck in the up position
oohh, that a tough one. you gotta, very carefully peal back the hand gaurd, the rubber where you hold onto it, at. Then releas the screws undeneath. Seems like you should be able to cycle the saw to its furthest out position, then remove the blade gaurd, uning some pliers of some sort you should be able to make the release, release.
Hope this helps
SOURCE: the lever won't stay depressed
mcdevito75 here, The lever mechanism could be worn OR the setting for darker / Lighter toast is set to Light, swtch to darker see if that helps.
