SOURCE: tredmill error code
Moat likely a problem with the motor control board. See treadmilldoctor.com
SOURCE: Treadmill runs then stops. E1 error and sometimes works fine.
Yes if speed sensor is too far from magnet it will not pick up belt movement. This confuses the computer and as a safety precaution it shuts the machine off. Find speed sensor and check for proper alighment with magnet.
SOURCE: Yamaha TW 200 starts but won't run.
If the bike has sat for a long period of time without being run - the gas that is sitting in the carb(s) will shellac.. Then the carb(s) would need to be cleaned and "rebuilt"..
SOURCE: error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
Description
Errors 30 through 33 all indicate the loss of communications or erratic communications between
the microprocessors in the upper PCA and the lower PCA. The trouble shooting procedures for
all of the are essentially the same. Error 30 is defined as upper PCA not receiving from lower
PCA. Error 31 is defined as faulty data received from lower PCA. Error 32 is defined as lower
PCA not receiving from upper PCA. Error 33 is defined as faulty data received from upper PCA
Possible Causes
1. An upper PCA to lower PCA interconnect cable is bad.
2. The interconnect cable at the upper PCA was mistakenly plugged into the CSAFE connector.
3. A 5.17 EFX equipped with version 1.01 upper and lower software.
4. A 5.17 with mismatched upper and lower software.
5. A defective lower PCA.
6. A defective upper PCA.
Possible Remedies
1. Substitute a know good interconnect cable between the upper and lower PCAs to determine
if the interconnect cable is defective.
2. Remove the interconnect cable from the CSAFE connector and insert it in the correct upper
PCA connector.
3. Replace the 5.17 upper and lower software with the most current software versions.
4. If only one of the upper or lower software is version 1.01, replace the version 1.01 software
with the most current version of software.
5. Substitute a known good lower PCA to determine if the lower PCA is defective.
6. Substitute a known good upper PCA determine if the upper PCAs defective.
