Building Materials Logo
JerryRay Espinoza Posted on Dec 30, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can I secure an aluminum shed to an existing concrete slab?
Hayward Cowan
Level 2:
Scholar:
  • Expert 59 Answers
  • Posted on Jul 05, 2021
Hayward Cowan
Expert
Level 2:
Scholar:
Answers
59
Questions
0
Helped
19761
Points
127
What are the dimensions and the configuration( sq. tube, flat, angle, channel) of the bottom support frame and how thick is the slab?.
BEST VAPPOR BARRIER FOR ARROW SHED INSTALLED ON CONCRETE SLAB
Foundation seal will work fine. Comes in 50' rolls.
2answers
Is there a concrete floor sealant that eliminated moisture seeming through the concrete slab?
if you want to seal the surface a epoxy paint is good !
but if the water come from under the concrete slab only a hole with aggregates ( small rocks ) and a swamp pump works fine !
My concrete slab is not level what should I do
How out of level is it? 1/8" from side to side, no problem. 2", problem. Spa needs to be pretty close to level.
You could add more concrete on top of slab and level that.
May 21, 2015 • Pool & Spa
Convert 30pounds per sq.foot to pounds per cubic foot(concrete=150#/cubic foot at 1in. thick conc. slab).
These are not the same, so cannot be directly converted.
Pounds per sq ft is a measure of pressure, while lbs / cu ft is a measure of density, weight per unit volume.
I think maybe what you are doing here is converting the weight of concrete in a 1" slab, where a sq ft would contain
1 x 1 x 1/12 = .0833 cu ft
The figure of 150 lb/ cu ft is correct for the average density of concrete, so the above slab would have
1/12 x 150 = 12.5 lbs/sq ft at 1" thickness
BTW that is a thin slab of concrete, insufficient even for a light-duty pathway. If you are referring to a screed for tiling or similar, that is cement.
2answers
How can i build a cement speed bump?
Is this for vehicles? If so concrete won't work as it will be too brittle especially when it gets cold.
How to repair a water pipe leak under a concreat slab
Things to consider are cut and replace -1. Concrete saw the affected area replace and re-concrete (impact hammer is another option but a concrete saw is neater and you can control the cut better.. 2. You can bypass the pipe. 3. Dig under the slab - you obviously would need to be near an edge.
What is post tension slab
It is a slab of usually Concrete that has Tension introduced upon it's Reinforcing rods/cables, AFTER it has been Poured, dried/set as opposed to a Pre-tension slab whereas the Tension is put on the reinforcing rod/cables inside the concrete and are Tensioned BEFORE or While it drys/sets
2helpful
K17 shed
This is Absco Sheds and the page that gives you instructional videos for assembling their sheds.
(Plus preparing the site, and constructing the concrete slab)
http://www.absco.com.au/videos.php
Top Building Materials Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Building Material Expert? Answer questions, earn points and help others
